Wiring Help For New Timer For Driveway Lights And A Separate Outlet Box - Electrical - DIY Chatroom Home Improvement Forum
Old 08-26-2013, 04:54 PM   #1
Wiring help for new timer for driveway lights and a separate outlet box
Hi everyone,
Hoping to get some assistance on the wiring diagram to accomplish the following:
-Two new lights being installed at end of driveway and the electrical lines for both being run up to house and into box as a new circuit.
- Before entering the house, would like to install a single gang box for outlets
- Once line comes into house, install indoor timer, to control lights at end of driveway.
Just having trouble visualizing the actual wiring diagram to make the switch control the lights but not the outlet box in between the two.
Thanks!
frankrizzo is offline   Reply With Quote
Old 08-26-2013, 05:02 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
You could feed your timer then run a 14/3 or 12/3(whichever you're using) to the box where you want the receptacle.
The black would be a constant hot and the red would be a switched hot to continue out to your lights.
of course all neutrals and ground go together and a GFI outside but, not for the lights.
wirenut1110 is offline   Reply With Quote
Old 08-27-2013, 01:30 PM   #3
Rewards Points: 170
If he is adding an outlet outside it must be 12 gauge wire and be GFCI protected. Also, once the wire leaves the outlet box, it can be 12-2 wire. Just make sure it is outdoor rated wire.
diyer111 is offline   Reply With Quote
Old 08-27-2013, 01:49 PM   #4
Rewards Points: 510
HUH? WT
The Following User Says Thank You to wirenut1110 For This Useful Post:
jbfan (08-27-2013)
Old 08-27-2013, 04:39 PM   #5
Rewards Points: 170
HUH? WT
At least where I am from. Any outdoor outlet must be on a 20 amp 12 gauge wire in order to power any sort of outdoor power tools, trimmers, lights, etc.
Old 08-27-2013, 04:46 PM   #6
Licensed electrician
Rewards Points: 1,038
This is not a NEC requirement for a 20 amp circuit.
Old 08-27-2013, 06:33 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Are you making this stuff up?
If it is fact a local amendment (which I doubt) don't quote it as code.
Coastal South Carolina
Old 08-27-2013, 06:34 PM   #8
Rewards Points: 170
I am not trying to make this up, it is something I saw elsewhere in this forum
Old 08-27-2013, 06:42 PM   #9
Oso954's Avatar
Rewards Points: 442
Which one of those is true ???
Oso954 is offline   Reply With Quote
Old 08-28-2013, 09:01 PM   #10
Rewards Points: 334
HUH? WT
i'm with you on this one, why 12 gauge? could be voltage drop.
circuitman is offline   Reply With Quote
lighting wiring diagram help, changed fan with lights to fan w/out and recesed lights snowmanZ Electrical 11 02-09-2013 06:38 PM
HELP!! 3 way wiring for lights with 3 zones BigSi Electrical 7 01-28-2013 11:10 PM
Wiring an Itermatic Wall Timer in a 4 way stitch SunnyInFlorida Electrical 8 04-28-2011 12:15 AM
Bathroom Renovation, separate outlet for whirlpool tub? ControlTech Electrical 9 06-23-2010 01:29 PM
Question about wiring and voltage with switches and lights rswurth Electrical 17 06-21-2010 12:12 AM
