Wiring Help Needed - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-11-2013, 08:41 AM   #16
Originally Posted by dmxtothemax View Post
YES !
You are quite right !
If the three wires are to the second switch ?
And the two wires are from the panel,
Where are the wires to the fixture ??
Unless the three wires are from the 2nd switch
and the other two wires are a switch loop from the fixture,
And neutral goes direct to the fixture,
Now thats a possble !
Now we just gotta test to confirm the theory.
The 3 wires are to the first switch and I think the 2 wires are switch loop as you suggest. How would I test this to make certain?
Frankbruno is offline   Reply With Quote
Old 11-11-2013, 04:55 PM   #17
dmxtothemax's Avatar
Rewards Points: 5,096
If it is a switch loop,
then one of the wires will be a hot supply from the fixture.
It will be hot all the time.
Test it with a volt meter.
The other wire should be the switched hot supply back to the fixture,
To test this use a test lamp, wire the test lamp between these two wires,
If both the test lamp and the fixture come on at about half normal
brightness, then its confirmed.
But if both lamps don't come on at half,
then it is NOT confirmed.
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Frankbruno (11-11-2013)
Old 11-11-2013, 05:19 PM   #18
My issue is the wires are not connected yet. They were connect in a box that had 3 different breaks. I ran a new cable from the breaker box for the other 2 breaks . I have this one left and I did not mark how they were connected so I am trying to figure which wires would go to the black coming from the breaker and which go to the white coming in from the breaker.
Solenoid Wiring w/plug Help Needed prabh_3 Electrical 5 10-21-2013 11:30 AM
Outlet Wiring Help Needed djcirello Electrical 2 02-03-2012 02:09 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
Wiring Help Needed aced19 Electrical 17 03-30-2009 10:30 AM
Help with bathroom wiring - URGENTLY NEEDED cfonseca Electrical 4 02-16-2007 02:42 AM
