Wiring Help - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-28-2008, 08:59 AM   #16
Light fixtures can build up a *lot* of heat and it is common for this to damage old wiring - the insulation crumbles when you move a wire as you learned!
If you have attic access to this fixture, you could maybe install a large junction box (plenty of room for connections) in the attic - say a foot back from the ceiling box, then cut off the damaged wiring, make the splices in the new junction box, then run a new wire from there to the ceiling fan box.
The old wire further back from the ceiling fan junction box should be ok since it would not have been exposed to the heat from a light fixture.
As to troubleshooting the fan. Sometimes it is simple. Did the switch on the fan get turned off? Or if that is not the problem, sometimes it is easier to troubleshoot if you remove the fan from the ceiling, then on the floor connect a length of wire with a plug on it to the fan wires, then plug it into an outlet and see if the fan works.
If it does not work, then take apart fan and inspect the wires inside and around the switch(s). Unlikely that the fan would have been fired or the light socket in the fan would have been fried, but wiring inside the fan may have come loose or been fried.
Billy_Bob is offline   Reply With Quote
Tags
breaker , wiring
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
1939 House Wiring upgrade jimmyfloyd Electrical 4 10-01-2008 04:56 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
