Wiring Help - Electrical - DIY Chatroom Home Improvement Forum
Old 01-12-2013, 06:44 PM   #1
Wiring help
I have four switches that work a fan and light combo. One of the switches just works the fan and the other three work the light. I was wondering how to take one of the light switches and wire recessed light up to it
Gerard Newport is offline   Reply With Quote
Old 01-12-2013, 07:27 PM   #2
Rewards Points: 14,014
Why is there three switchs to run just one light?
Old 01-12-2013, 07:31 PM   #3
There on different walls
Old 01-12-2013, 07:34 PM   #4
Do you want all the lights to come on at the same time? (including the light in the fan)
Old 01-12-2013, 07:39 PM   #5
joed's Avatar
Rewards Points: 13,344
It depends on how the switches are wired. It is very likely that you can not do what you want without some new cabling to the switches.
Old 01-12-2013, 08:59 PM   #6
No I want to be able to turn them on separate
Old 01-12-2013, 09:24 PM   #7
Licensed electrician
Rewards Points: 1,778
Then you will need to find a power source and run new cables.
Old 01-12-2013, 10:06 PM   #8
Got any ideas how I can run a new wire from the breaker box. It's a two story house and the breaker box and living room are on the lower floor
Old 01-12-2013, 10:24 PM   #9
You may not even need to go to the panel, depending on the existing and new load.
Gerard Newport (01-13-2013)
Old 01-12-2013, 10:37 PM   #10
The only things on the circuit is the fan. Where could I get the power from
Old 01-12-2013, 10:38 PM   #11
I think the plug ins are on the same circuit and I only have a tv and and cable box plugged up
Old 01-12-2013, 11:33 PM   #12
Child Alert! Pull Up!
fltdek's Avatar
#Removed#
fltdek is offline   Reply With Quote
Old 01-13-2013, 11:31 AM   #13
So does anybody else have any ideas how to do this
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
