-   -   Wiring help (http://www.diychatroom.com/f18/wiring-help-168952/)
Gerard Newport 01-12-2013 07:44 PM
Wiring help
I have four switches that work a fan and light combo. One of the switches just works the fan and the other three work the light. I was wondering how to take one of the light switches and wire recessed light up to it
joecaption 01-12-2013 08:27 PM
Why is there three switchs to run just one light?
Gerard Newport 01-12-2013 08:31 PM
There on different walls
joecaption 01-12-2013 08:34 PM
Do you want all the lights to come on at the same time? (including the light in the fan)
joed 01-12-2013 08:39 PM
It depends on how the switches are wired. It is very likely that you can not do what you want without some new cabling to the switches.
Gerard Newport 01-12-2013 09:59 PM
No I want to be able to turn them on separate
Jim Port 01-12-2013 10:24 PM
Then you will need to find a power source and run new cables.
Gerard Newport 01-12-2013 11:06 PM
Got any ideas how I can run a new wire from the breaker box. It's a two story house and the breaker box and living room are on the lower floor
Jim Port 01-12-2013 11:24 PM
You may not even need to go to the panel, depending on the existing and new load.
Gerard Newport 01-12-2013 11:37 PM
The only things on the circuit is the fan. Where could I get the power from
Gerard Newport 01-12-2013 11:38 PM
I think the plug ins are on the same circuit and I only have a tv and and cable box plugged up
fltdek 01-13-2013 12:33 AM
#Removed#
Gerard Newport 01-13-2013 12:31 PM
So does anybody else have any ideas how to do this
