Old 10-07-2012, 09:32 AM   #1
Wiring Help
Hello,
Need help with wiring a new switch. I have attached a picture of what is needed. Basically, I have a existing porch light that is giving power to the "dusk-to-dawn" light. I would like the porch light to be controlled by a switch. Can someone do me a diagram on how to connect the switch wires from the existing porch light?
Thanks in advance..
https://picasaweb.google.com/lh/phot...eat=directlink
Pipecreek
pipecreek is offline   Reply With Quote
Old 10-07-2012, 09:39 AM   #2
Licensed Electrician
k_buz's Avatar
Wiring Help
So what do you exactly want to do?
How is the "porch light" controlled now? Is there one switch that controls the "porch light" and the dusk to dawn light and you want to add a second switch?
Location...Location...Location
k_buz is online now   Reply With Quote
Old 10-07-2012, 01:43 PM   #3
Wiring Help
That is correct K-Buz.
The current porch light is being fed from a fan light that comes from a switch in the wall. Guess I should of put that down also; sorry. I need to put a new switch outside the house so I can turn on and off outside. Make sense?
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
