Old 09-09-2012, 12:11 PM   #1
Wiring help!
I have a little problem figuring out how to wire my shop. From the box, a line goes all the way to the other side of the shop. In the middle is where that line is intersected by a switch and the string of lights that run in a loop that ends up in the middle. I hopefully attached a photo of a diagram i drew to help you see what i am explaining.
andyrew is offline   Reply With Quote
Old 09-09-2012, 12:30 PM   #2
Master Electrician
Wiring help!
So, is there an issue or a question?
brric is online now   Reply With Quote
Old 09-09-2012, 12:34 PM   #3
Wiring help!
SO what is the question?
hammerlane is offline   Reply With Quote
Old 09-09-2012, 12:39 PM   #4
Wiring help!
Oh I'm sorry. I can't figure out how to wire the switch and the lights into that line that goes from the box to the outlet. So the outlet would always be on, but the lights would operate on the switch.
Old 09-09-2012, 12:48 PM   #5
Wiring help!
Try this.
Old 09-09-2012, 12:51 PM   #6
Master Electrician
Wiring help!
The white from the cable going to the lights is connected to the whites going to the recep. The black from the cable going to the lights is connected to one terminal of the switch. A pigtail from the blacks going to the recep is connected to the other terminal of the switch. Grounding connections omitted for clarity.
Old 09-09-2012, 12:52 PM   #7
Wiring help!
forgot the diagram. No grounds shown for ease of drawing
Old 09-09-2012, 12:52 PM   #8
Master Electrician
Wiring help!
Originally Posted by hammerlane View Post
Try this.
That may not work.
Old 09-09-2012, 12:53 PM   #9
Wiring help!
Originally Posted by brric View Post
That may not work.
you mean doing nothing??
Old 09-09-2012, 12:59 PM   #10
Wiring help!
OK thanks to the both of you. I'll be trying this out here in a bit and then I'll be back on here and tell you how it goes.
Old 09-09-2012, 01:06 PM   #11
" Euro " electrician
frenchelectrican's Avatar
Wiring help!
If this in the garage then normally I do is keep the light and receptales seperated so in case something trip the receptales the lights stay on.
That only if you have breaker box in the garage that will make the differnce there.
Merci,
Marc
Old 09-09-2012, 01:35 PM   #12
Electrical Contractor
Wiring help!
No neutral at the switch!
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 09-09-2012, 01:43 PM   #13
Wiring help!
let him run a 12-3 cable then to the switch
Old 09-09-2012, 06:53 PM   #14
Wiring help!
Alright everyone, I got the lighting all hooked up thanks to Hammerlane's diagram! So tyvm.
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
