Wiring A Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2011, 09:13 PM   #1
Wiring a Heater
I'm installing a heater in my garage. I've run 6-2 with a 50 amp double pull breaker. Below are some images of the heating unit. I'm needing to know how to wire the heater. Thanks for the help. It's a Ouellet 10,000 Watt; Model# OASU10000T; BTU 34,120; 240 Volt.
jefstrick is offline   Reply With Quote
Old 10-24-2011, 09:42 PM   #2
liscenced electrician
Rewards Points: 538
here ya go. L1 L2 and ground. It looks like its got a thermostat preinstalled, so you just need to provide power
jimmy21 is offline   Reply With Quote
Old 10-25-2011, 02:42 AM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,970
Jimmy got it. Just to clarify a bit more, connect the two hot wires from your new 50A circuit (black and red or black and white probably, depending on your wire) to the L1 and L2 terminals. Connect your ground wire to the lug with the green screw. That's it.
mpoulton is offline   Reply With Quote
Old 10-25-2011, 07:54 AM   #4
Great! Thanks so much for the quick reply!
The heater has a turning knob on the back of the heating unit. Is this just an On/Off and setting knob or is it also the thermostat? In the first picture this is in the very bottom right corner. I was wondering if I could install a programmable thermostat that I would mount on the wall in the garage. Is this possible? If so, how would I do this? Thanks
Old 10-25-2011, 09:59 AM   #5
Rewards Points: 538
Looks like its a thermostat. You couldn't use a programmable thermostat because they aren't rated for that massive heater. You would need to wire the thermostat to a contractor and the heater to the contractor to make it work
Old 10-25-2011, 01:35 PM   #6
There is already a contactor in the heater. It's the big thing towards the left. If you get a thermostat intended for use with line-voltage baseboard heaters and wire it to the coil of that contactor, it will control the heater.
Old 10-26-2011, 09:31 AM   #7
Rewards Points: 768
most line voltage thermostat needs a 500w load minimum so it wont work for contactor. (you can try it)
you need a 24vac thermostat (furnace type thermostat), a relay and a control transformer (240-24vac). Those are options when you order those type of heaters. option relay is shown on picture, is there others parts then those on picture?
carmusic is offline   Reply With Quote
Old 10-26-2011, 11:20 AM   #8
I=E/R
a7ecorsair's Avatar
Where did you come up with this?
a7ecorsair is offline   Reply With Quote
Old 10-26-2011, 12:35 PM   #9
Rewards Points: 768
it is what is marked on datasheet of most programmable line voltage thermostat
http://www.honeywellstore.com/store/...ing-manual.pdf
(minimum load of 2A)
he could uses an old mechanical thermostat which would work ok
Old 10-26-2011, 03:45 PM   #10
I=E/R
a7ecorsair's Avatar
I see...
The themostat is in series with the heater element and needs a certain amount of current to flow to operate. Notice that this type of thermostat does not have an OFF that interrupts both legs of the 240 volts.
Old 11-02-2011, 10:43 AM   #11
th140
Thanks for all the input. I called the manufacture just to ask if they had a thermostat built specifically for this unit. He said they did (which was a different response I received from the distributor). The manufactures are from Canada and they only have this product on the Canadian side of their website which may be why the distributor didn't see it... Anyways, the below link is the unit he said would work. It's powered by batteries but, he said all I have to do is pull the two terminals off the thermostat in the heating unit (bottom right side of the 1st picture) and run those lines in series through this programmable thermostat. That sounded really good, almost to good to be true so I wanted to post this to see what you all thought. Thanks again for the help!
http://www.ouellet.com/line-voltage-...ecs.aspx?i=182
Old 11-02-2011, 02:42 PM   #12
Rewards Points: 768
yes it shoud work with this one since it has relay output and runs off batteries
i see that it is very new model. that good since we wont have to add transformer to control contactors
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
wiring an in-wall heater mattkslc Electrical 9 03-05-2011 10:19 PM
Wiring for replacing a bathroom fan, heater, light and night light unit. tgallopbs Electrical 24 11-02-2010 09:57 AM
Baseboard heater wiring question Master Brian Electrical 21 10-07-2010 09:28 PM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
