Wiring/Ground Screw Dilemma - Electrical - DIY Chatroom Home Improvement Forum
Old 09-25-2010, 01:23 PM   #1
Wiring/Ground Screw dilemma
Hey, guys, newbie here. I'm trying to get my outdoor garage lighting hooked up, but there's one problem. The directions say to attach the copper wire to the ground screw--but there are two ground screws. There's one on the mount, and one on the light.
Can I just attach the one from the light (which is attached with a green screw) to the copper wire coming from the house, and bypass the one on the brass mount?
joopy44 is offline   Reply With Quote
Old 09-25-2010, 01:36 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
you need to attach to both. Run the ground wire long enough so you can simply wrap it around the screw in the box and then on to the screw on the fixture.
Old 09-25-2010, 04:05 PM   #3
Success! Thanks for the tip, nap!
Stuck Screw IceTreay General DIY Discussions 11 09-09-2010 01:56 PM
Azek Decking and Cortex Screw System EdtheC Flooring 2 08-27-2010 07:48 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 10:47 PM
Sheared head on Tapcon screw - how to remove? mkuether Remodeling 9 12-04-2008 08:18 PM
