Wiring A GFCI In A Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 02-09-2012, 10:58 AM   #1
Wiring a GFCI in a bathroom
My current outlet in the bathroom has three cables of 14/2 wires connected to it. One cable would be the line coming in to the box and the other two sets of 14/2 cables would be continuing the circuit to other areas of the house. How do I wire this outlet to a GFCI ?
Takecharge is offline   Reply With Quote
Old 02-09-2012, 11:22 AM   #2
Julius793's Avatar
The line to the line an the other 2 to the load.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 02-09-2012, 11:48 AM   #3
Julius793. As the GFCI has only terminals with no additional connections available on its back side, would it be wise to join the the two white load wires together with a marrette and include a single white wire which would be used to connect to the load side of the GFCI? Similar connection for the black load wires. Not sure how much room there will be in the box for the GFCI plus a couple of marrettes though.
Old 02-09-2012, 11:53 AM   #4
Julius793's Avatar
The gfi doesn't have two wholes for each screw? Anyway yes you can pigtail the blacks and whites.
The Following User Says Thank You to Julius793 For This Useful Post:
Takecharge (02-09-2012)
Old 02-09-2012, 12:04 PM   #5
Looked again at the GFCI and you are correct -- two holes for each screw. Much better than pigtail idea. Thanks so much for your help!
A few wiring questions (GFCI, AFCI, 2011 NEC) mudworm Electrical 7 10-10-2011 07:32 PM
GFCI in basement bathroom... wackerjr Electrical 1 01-19-2011 11:40 PM
wiring switch to gfci plug wendl Electrical 5 04-05-2010 09:02 PM
Wiring Problem in Bathroom notasparky Electrical 7 10-27-2008 06:34 PM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
