Old 06-29-2012, 05:25 PM   #1
Wiring Generator to Backfeed Breakers - Neutral and Ground Wires?
Hi! I'm planning on using an interlock kit (code approved model) when connecting my generator to my home's main power panel, as follows (drawing attached):
7500W generator (Generac GP7500E) with L14-30 generator cable connecting generator's 240V 30A outlet to an L14-30 inlet box (on house), then connect the inlet box to 30A dual-pole backfeed breakers in the primary power panel using 10/4 wire.
Backfeed breakers and main panel input breaker will be mutually exclusive using interlock (only one can be on at any given time).
My question is do I run both the neutral and ground wires from the inlet box to the neutral bus bar in this primary power panel, or just the neutral wire? If just the neutral wire, what's done with the ground feed? Anything?
One other secondary question: Are backfeed breakers unique from standard breakers? Do I need to find specifically backfeed breakers, or will your standard 30A dual-pole breakers work for this application?
Thanks for your help!
Wiring Generator to Backfeed Breakers - Neutral and Ground Wires?-generator-wiring-diagram-interlock-small.jpg
tjnoff is offline   Reply With Quote
Old 06-29-2012, 09:16 PM   #2
Lic Electrical Inspector
electures's Avatar
What type of interlock device? Who makes it?
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 06-29-2012, 09:29 PM   #3
You would use an ordinary breaker for backfeed purposes.
The best way to arrange ground and neutral for a backfed generator is to unbond the neutral from the generator's frame and ground connection inside the generator. Occasionally this cannot be done easily in which case I would be tempted to leave the green wire unhooked somewhere in the wiring between panel and generator. I would not mutilate a generator to get its neutral and ground unbonded.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 06-29-2012, 09:54 PM   #4
Master Electrician
Connect the neutral and the ground wires from the generator to the load center. DO NOT tamper with the generator.
brric is online now   Reply With Quote
Old 06-29-2012, 09:57 PM   #5
E2 Electrician
stickboy1375's Avatar
If you cannot remove the N-G bond at the generator, then you must switch the grounded connector at the transfer switch.
Old 06-29-2012, 10:05 PM   #6
Master Electrician
And why would that be?
Old 06-29-2012, 10:27 PM   #7
E2 Electrician
You can only have one point where your N-G are bonded together.
Old 06-29-2012, 10:32 PM   #8
Master Electrician
What do you think would be the consequences? It works fine on my personal home and others I have done.
Old 06-29-2012, 10:39 PM   #9
Master Electrician
A generator is not considered a permanent part of the electrical system. Removing the bond in the generator voids the warranty. Also if the generator is used for anything other than back feeding the house it could be potentially dangerous with the bond removed.
Oddly enough this is one of the reason a genny panel switches out the neutral that you argued so much about not needing.
brric, what's you've in essence done is run a ground and a neutral in parallel with each other, in theory they can both carry some of the current.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 06-29-2012, 10:43 PM   #10
E2 Electrician
Its a code violation, plain and simple. And just because it works, doesn't make it correct.
Old 06-29-2012, 10:44 PM   #11
Master Electrician
That is correct. It is a temporary plug and cord connection. It is not intended to be permanent. Also, removing the bond would create a possible generator fault clearing issue.
Old 06-29-2012, 10:45 PM   #12
E2 Electrician
I didn't argue anything, I told you current doesn't seek the earth.
Old 06-29-2012, 10:46 PM   #13
Master Electrician
i should have clarified, only the last bit of that post was directed at you brric, the first was for stickboy.
never thought of the fault issue, good point.
Old 06-29-2012, 10:46 PM   #14
E2 Electrician
And is still a violation.
Old 06-29-2012, 10:47 PM   #15
E2 Electrician
I know.
Tags
backfeed, breakers, interlock
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 03:10 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 12:33 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
