I have the exact same timer and I read your (jbfan) reply and it is rigth on with the instructions. The problem I have is I have three switches in the same area and i am replacing one of them with the GE Digital Timer. There are three big wire nuts connecting 3-4 wires each, but none of them are white ! All the wires are black. I have the 2 black wires that are bound together and then the single black. I can connect the black on the timer ti the double black and the red to the singel black, but how can I locate the correct wire(s) for the white ??? I greatly appreciate your help.
Originally Posted by jbfan
If the wires are black, red, white, and green, the it will wire like this.
The white wire connectes to all the whites, the two black wires connect to the black on the timer, and the red connects to the lone black, switch leg.
Green goes to bare grounds.
Are you sure about the red wire connecting to the neutral.
If you connect it like that, nothing will work because there is not a load wire.
Do you have a number to look up online.
ALSO, Turn off the breaker!
