Old 06-12-2012, 01:13 PM   #1
wiring gas pool heater - Ontario ESA
Is a disconnect required for a pool heater install outside a pool house?
Pump is behind fence greater than 3 mts from pool. Can cabtire be run
from wall switch to heater if mechanically protected outside pool walls?
Also can #6 pool ground be run in same conduit with feed to pool house.
Service to pool house will be 12/2.
Tks - dont do to many pool installs
2buddy is offline   Reply With Quote
Electric Water Heater Wiring tech14 Electrical 6 09-23-2011 02:53 PM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Issue with thermostat wiring for baseboard heater jschell Electrical 3 01-30-2011 08:30 AM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 04:32 AM
