Wiring Garbage Disposal Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 06-08-2013, 02:12 PM   #1
Wiring garbage disposal switch
I am looking for a wiring diagram/instructions for wiring a garbage disposal switch . I have a dedicated 20 Amp circuit run from my electrical panel to a switch above the counter. I want to wire this switch to an outlet that the disposal will plug into under the sink. I also have a 12 Amp two-wire line run from the single pole switch to the area under the sink where I want to install an outlet box for the disposal to plug into.
I just need instructions on how to make the wiring connections. I do not want to use the outlet for a dishwasher or anything other than the disposal.
whodikai is offline   Reply With Quote
Old 06-08-2013, 02:22 PM   #2
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Wire nut the 2 whites together ...each individual black goes on each individual screw on the switch ....doesn't matter
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
whodikai (06-08-2013)
Old 06-08-2013, 02:27 PM   #3
MarginallyQualified
Rewards Points: 2,464
Be sure. Far more common is the 20A circuit feed run to a box BELOW the sink which is then shared with the dishwasher. Single yoke receptacle for each appliance to plug into there... and a switch loop up the wall for the disposer.
The Following User Says Thank You to TarheelTerp For This Useful Post:
Old 06-08-2013, 03:04 PM   #4
Rewards Points: 516
We always run 2 circuits one for each, ck manufactures installation instructions also
Old 06-08-2013, 04:04 PM   #5
Am sure
I ran the circuit myself to the switch for the disposal. I also ran separate circuit for dishwasher ...the dw is not by the disposal ....I am going to hard wire the dw, directly from the panel box.
I just need to get my connection straight for the disposal. Again, I have a direct 20 amp circuit from the panel box to the single pole switch that will control my disposal. I already ran a 12-2 wire from the box where my switch w ill be installed to to outlet where I want to plug in my disposal. I want that outlet dedicated to the disposal and nothing else. Thanks.
Old 06-08-2013, 05:44 PM   #6
Rewards Points: 512
And at the disposal receptacle, the White goes on the Silver screw, while the Black goes on the Brass screw.
Installation is the Reverse of Removal.
The Following 2 Users Say Thank You to sirsparksalot For This Useful Post:
Philly Master (06-08-2013), whodikai (06-08-2013)
Old 06-08-2013, 09:34 PM   #7
Thanks for the info, Philly Master and Sirsparksalot...this will help!
The Following User Says Thank You to whodikai For This Useful Post:
Philly Master (06-09-2013)
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 10:43 AM
help wiring a DPDT pushbutton switch fromscratch Electrical 9 10-11-2011 10:26 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
4 way switch wiring ponch37300 Electrical 9 02-16-2009 10:58 AM
