Wiring Garage Outlets From A Subpanel - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-25-2012, 08:00 PM   #16
JuzRick's Avatar
Originally Posted by ACR_SCOUT View Post
Hello everyone.
I have an attached garage (26x30) which is finished so I don't want to break into the walls and ceiling. It has two 15amp plugs in the wall, one 15amp plug in the ceiling (garage door opener), and two lightbulbs in the ceiling.
When I had some remodeling done I had the contractor install a 100 amp sub in the garage. So I have some sanity questions.
The sub panel is surface mounted. It is my intention to run surface mounted EMT for plugs that will be used for normal garage stuff (drills, table saw, crosscut). My thought is one 20amp breaker per wall. I am thinking of running the EMT to the ceiling and then drop down to the first plug box then plug box to plug box.
One of the things I do notice is that the lights in the garage dim when my table saw first powers up. It is on a 115v plug should I rewire it to 240v?
Does my plan sound ok?
How many plugs per circuit should I run?
Do I need to run a separate ground or can the EMT be used as the ground?
I have looked into multi-wire branch circuits but there seems to several cons to doing that, thoughts?
Question about sub panel grounding. I read in a different post that the sub panel is suppose to have a #6 ground running to two 6-foot grounding rods outside. Is this a fact? (I already knew the ground and the neutral in the sub panel are to be isolated.
Can I run an underground circuit (proper depth of course) to my shed which is about 30-feet away? I want to put a motion flood light and inside lights out there.
Thank you,
Fred
ANSWER/1ST Q: 1) RE: you must start with 6'ft from the entrance way- then after every 12'ft from that point. Anything counter wise got to be at least mounted 4"in from the top of the counter.
2) Receptacles at 20 amps. Specific machinery(equipment) other than what you listed.. needs to be on a dedicated circuit as specified on the label stamp on the machine.
ANSWER/2ND Q: 1) The light should be very well on its own circuit- 15 amp precisely.
ANSWER/4TH Q: 1) Answer above-->(How many plugs per circuit should I run?)
ANSWER/5TH Q: EMT can be used
ANSWER/7TH Q: Yes also correct on the ground rods.
ANSWER/8TH Q: Yes you can. And why not branch of the 15 amp circuit in the garage(being your running it from house to garage?
JuzRick is offline   Reply With Quote
Old 11-25-2012, 08:33 PM   #17
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
JuzRick, did you read the entire thread.
There is no requirment to have receptacles 12' apart in a garage.
The garage is attached, so no need for the ground rods.
Where do you get the requirement for the receptales to be on a 20 amp circuit?
Old 11-25-2012, 08:44 PM   #18
JuzRick's Avatar
I guess i missed that part on the garage being attached. And yes receptacles 20 amp circuit..12-3 conductor. That's in the book NEC. I forgot allot of you place 20 amps on #14. That's why when you come further down south, they make you reexamine for a SC License.
Old 11-25-2012, 08:45 PM   #19
JuzRick's Avatar
That's 20 amp 12-2/12-3 conductor
Old 11-25-2012, 08:47 PM   #20
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Code reference please?
No, that is only allowed in very specific situations. Garage receptacles are not one of the situations.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
frenchelectrican (11-25-2012), jbfan (11-25-2012)
Old 11-25-2012, 09:01 PM   #21
JuzRick's Avatar
K_Buz: SC is different. I will reference it from my NEC Book. As I said before.. depending on the state your in, as for here- its not of code. I've learned that strictly by an ME before getting my credentials as a RE.
It was also pointed out on the test too! Im not arguing with anyone. But I know what I know. Here depending on that size of the garage as the guy- its required! Thats why most you guys who relocate here hates it. I GUESS i comprehend you guys now.
I thought code was the same in every state until yrs later finding out differently!
I will reference it. If I'm incorrect I will admit to just that. K_Buz- your a good guy thus far...
Old 11-25-2012, 09:05 PM   #22
k_buz's Avatar
If it is a local amendment, we would have no way of knowing. It is not, however, in the NEC. Don't bother looking, you won't find it.
Old 12-01-2012, 05:04 PM   #23
US ARMY RETIRED
ACR_SCOUT's Avatar
Originally Posted by frenchelectrican View Post
As long your interal ( house ) breaker say 60 amp then it mean you have more than enough room to load it up to gills so you can have some pretty serious power tools running in this subpanel.
Note: look at the sticker either right or left side of the tub ( panel ) see if you have straight 12 space or 12-24 verison due this size of breaker box it is not too uncommon to see it listed to use the tandem breaker in case you want add more circuits.
Merci,
Marc
The 60amp sub is wired to a 100amp breaker in the main panel.
I looked at all the stickers on the sub panel but did not see anything about tandem breakers.
ACR_SCOUT is offline   Reply With Quote
Old 12-01-2012, 05:25 PM   #24
k_buz's Avatar
You won't see anything written. You will see a diagram. Who's panel is it and what is the model number?
Is there a 2P 60A breaker in the sub?
Old 12-01-2012, 05:27 PM   #25
US ARMY RETIRED
ACR_SCOUT's Avatar
It's a cutler-hammer and if I read it right it seems to be a panel to wire an auxiliary generator to. Hmmm. Might not be a true sub panel.
Checking detatched garage wiring. weekendjob Electrical 1 05-02-2012 07:34 PM
Wiring garage for compressor, welder, and outlets Bentley Electrical 3 03-08-2011 11:24 AM
Garage Subpanel Wiring Question Joe85 Electrical 10 03-06-2011 03:14 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Legal to have subpanel in garage? gante Electrical 36 03-13-2009 03:27 PM
