Wiring Garage For Kiln - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 07:50 PM   #1
Wiring garage for kiln
What is the cost estimate of wiring garage for kiln with 240v / 50 amp/ 6 gauge wire? Ithecrecptacle will be about 20 feet from the panel box
Leecat52 is offline   Reply With Quote
Old 12-30-2011, 08:08 PM   #2
DIY staff
Rewards Points: 7,174
This a a DIY site--How much? Questions can not be answered successfully here---To many variables.
Please contact a local electrician for a quote---Mike--Moderator---
Old 12-30-2011, 08:31 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Leecat52 View Post
What is the cost estimate of wiring garage for kiln with 240v / 50 amp/ 6 gauge wire? If the recptacle will be about 20 feet from the panel box
With no obstruction to get through in order to get the wire from the panel (that has space for the new circuit to the kiln location) the DIYer will only need the material and about an hour of their time (two at most).
Go shopping for 20 feet of wire and the breaker and the receptacle.
hth
Old 12-30-2011, 09:14 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,858
I'd call it more of an all-afternoon project if you're new to wiring, but it's not hard. It would probably be in the neighborhood of a few hundred bucks to have it done, or probably about $100 in material to DIY. This could vary by a large degree depending on the specifics of the installation.
If you could post photos or a very detailed description of the path from the panel to the receptacle location, and the spaces and construction materials involved, we can provide more specific advice on the best way to handle it.
mpoulton is offline   Reply With Quote
Updating wiring for detached garage question inlet510 Electrical 13 09-23-2011 03:22 PM
Detached Garage Wiring elpht_man Electrical 5 09-23-2011 07:31 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Detatched Garage Wiring Methods Perry401 Electrical 9 06-01-2011 10:00 PM
Wiring garage workshop Kay Man Electrical 10 08-28-2008 01:04 PM
