Wiring A Garage. How Does This Look? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-08-2009, 11:11 AM   #1
Wiring a garage. How does this look?
I live out in the country and am building a garage/shop. (detached.) I took some pictures of my wiring project and wanted some helpful suggestions. I am using a 100 amp subpanel. If it looks funny, I mounted it upside down. The instructions said to mount it this way if the panel was going to be bottom fed. (WHich this one is).
Also, someone on a posting forum said I need some sort of hold down kit for my main breaker in the picture???
Any help is appreciated!!!
http://www.flickr.com/photos/4...706@N03/
stryped is offline   Reply With Quote
Old 09-08-2009, 11:21 AM   #2
Licensed Pro
The backfedmain breaker should have a holddown kit installed. If you bought the panel with the breaker already installed, the kit should also already be there.
The bare grounds should be going to the grounding bus attached to the enclosure, not to the isolated bus.
Old 09-08-2009, 11:25 AM   #3
I am not sure what you mean by "backfed" but this panel did come with the main breaker but no sort of "hold down". I am not sure exactly what that is.
My panel is upside down. The instructions said to mount it that way if it will be bottom fed. "Which it will be". The grounding bus is on the left and the neutral on the right. So, are you saying my bare grounds should go on the small buss bar to the left of the main ground bus bar? That is easy enought to do but what is the difference?
Old 09-08-2009, 12:17 PM   #4
I see what looks like a green grounding screw on the bottom left
Does that connect somehow to the bus above you are using for grounds?
Usually the neutral bus is bigger since you can't double up neutrals
Ah---looks like the grounding bus you should be using is attached to the case on the left side
The grounds do need to be grounded to the case & then ground rods
Have you put in grounding rods yet?
I can't seem to see where the 2 Main hot feeds will connect
Possibly hidden by the breaker?
4 feed required, 2 hots, neutral & ground
A garage is also required to have circuits GFCI protected
Old 09-08-2009, 12:37 PM   #5
Rewards Points: 78
Get some support for the cables over the garage door. Those are pretty expensive staples. They scream DIY, but then you are a DIY. lol! Looks pretty good. Are you going to put up drywall?
Old 09-08-2009, 01:40 PM   #6
I dont have the feeder wire yet. I believe that screw attaches the grounding buss to the cabinet. Another grounding screw came with the panel for the neutral buss but I did nto install it because I thought you were not supposed to. I do have a GFCI outlet feeding all other outlets. Have not but up the ground rods yet.
Old 09-08-2009, 01:41 PM   #7
You mean the cables that run perpendicular from one rafter to another? I plan on maybe installing some 2x4's for support.
I really thought about putting up osb. Think that would be alright?
Old 09-08-2009, 02:15 PM   #8
Rewards Points: 1,016
1x4 would be fine to create a raceway for support.
OSB would be ok - I used the heavy 4x8' 1/4" thick pegboard panels in my workshop. Prefinished white so did not even paint, look plenty good for a workshop, and provides ad hoc storage everywhere. I screwed them rather than nailed - makes it easy to remove/change a panel if need be in the future.
Old 09-08-2009, 02:36 PM   #9
I like that idea. What did you use for the ceiling? Did you insulate under the pegboard?
Old 09-09-2009, 01:49 PM   #10
Rewards Points: 78
Yea, Just so they don't sag and get caught in the door when opening or closing. Job looks good. Post pics when you get the walls up.
Old 09-09-2009, 03:33 PM   #11
Licensed electrician
Rewards Points: 1,248
Does the pegboard or OSB have a 15 minute fire rated finish?
Old 09-09-2009, 03:45 PM   #12
47_47's Avatar
Rewards Points: 44
Does a detached garage need a fire rating?
47_47 is offline   Reply With Quote
Old 09-09-2009, 04:17 PM   #13
See 334.10(3) Cables shall be concealed within walls. floors or ceilings that provide a thermal barrier of material that has a 15 minute finish rating as identified in listings of fire-rated assemblies.
Old 09-09-2009, 04:49 PM   #14
I have plywood on top of the ceiling joists providing for overhead storage - so have not a finished ceiling per se. I had thought about putting 4x8 sheets of bead board as a ceiling for aesthetics, but - it's a workshop...
And yes, I insulated under the pegboard.
Old 09-09-2009, 05:56 PM   #15
NMB does not need to be concealed within walls on a garage. Many garages do not even have drywall, especially detached garages
Not even required in a basement
Wiring Main-Breaker Box in Detached Garage wstribl Electrical 15 05-11-2013 06:15 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 12:09 PM
Critique my wiring plan for my garage tigereye Electrical 10 03-24-2009 10:55 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 12:52 PM
