Old 03-07-2011, 08:08 PM   #1
Wiring garage for compressor, welder, and outlets
I'm running a sub panel to my garage 50 amp's. My compressor runs at 15 amps 220, welder around 30 amps 220 and probably around 6 110 outlets. The run from my houses panel to garage is around 70 feet do you think 6-3 wire is a heavy enough gauge to do the job. I won't be running the compressor and welder at the same time.
Bentley is offline   Reply With Quote
Old 03-08-2011, 11:29 AM   #2
J. V.'s Avatar
At the top of this page you will see a search function. Here, using the correct search keywords you will find all the answers to all your questions. This is by far the most frequently question asked on this forum. There are tons of archived instructions and suggestions from licensed electricians. Use the search function. There is no reason to re-invent the wheel.
Old 03-08-2011, 11:58 AM   #3
6/3 copper will be fine.
Do It Right is offline   Reply With Quote
Old 03-08-2011, 12:24 PM   #4
Thanks and sorry I'm new to this site and app
Garage Wiring VinceA Electrical 14 09-11-2010 09:05 PM
Wiring a Garage magic781 Electrical 2 04-28-2009 12:57 PM
Critique my wiring plan for my garage tigereye Electrical 10 03-24-2009 10:55 PM
Correcting 40+ years of screwy wiring Badfish740 Electrical 3 12-28-2008 10:19 PM
Question about wiring outlets together firemanpato Electrical 5 01-05-2008 04:52 PM
