Wiring Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2009, 12:04 AM   #1
wiring garage
I ran wires in pvc underground out to the garage.We just ran 2 hots for 220 and grounded at the garage with 2 ground rods.Somone said if the run is over x amount of feet the ground wire should run back to the original source.This will probably never happen since the trench was filled in years ago.Is this safe,also read that romex can`t be run in pvc cause moisture deterierates the nylon or something.I though at the time it was safer than just burrying outdoor wire without a hard covering.Please let me know the cons and hopefully pros of doing it the way we did or do I need to dig it up and start over.
handywho is offline   Reply With Quote
Old 02-16-2009, 01:06 AM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
What are you using for a neutral?
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-16-2009, 05:43 AM   #3
Is there a sub-panel at the garage? Can you get a picture of it? Was this UF wire?
jerryh3 is offline   Reply With Quote
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Wiring a garage reverendcolin Electrical 34 11-10-2008 04:53 PM
Wiring garage workshop Kay Man Electrical 10 08-28-2008 12:04 PM
Two Family Duplex - Garage Wiring Question Moonlight24 Electrical 2 06-22-2008 10:31 AM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
