Wiring Garage For 220 - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 03-17-2010, 09:24 PM   #46
OH NO !! An Engineer !!
I've never heard of it
So unless its specific to your area....
Old 03-17-2010, 09:58 PM   #47
Rewards Points: 866
I kind of thought as much. I will check with the city when I go for a permit, but I don't think it has any special requirement. Thanks.
Klawman is offline   Reply With Quote
Old 03-18-2010, 06:31 AM   #48
Electrical Contractor
jbfan's Avatar
Rewards Points: 388
An electric water heater is never plugged into a receptacle.
They will always be hard wired.
Don't worry about things that were not installed in your house when it was built.
If it was required then, it would have been installed, otherwise you would not have been able to move in.
If the house was incomplete, then a CO would have never been given.
jbfan is online now   Reply With Quote
Old 03-18-2010, 11:32 AM   #49
kbsparky's Avatar
That outlet is not for a water heater. If you are in California, then it is most likely an outlet for an electric car charger.
One of those mandates by your local gov't that costs everyone bucks, but provides little benefit.
-KB
Old 03-18-2010, 12:07 PM   #50
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I noticed that his outlet isn't a duplex and if memory serves me it has a neutral slot that looks like a letter "T" with the base of the "T" pointed to the edge of the receptacle. I told him I believe it is a 20A receptacle and he says he probed it and it measured 30A.
I suspect you should disregard advice from your neighbor. You can't probe an outlet that does not have a load plugged into it and operating and get a 30 amp measurement. The breaker may say 30 amps on it. What he should have measured was voltage.
Anyway it is irrelevant. to satisfy your curiosity you can identify the receptacle here....
http://www.westernextralite.com/resources.asp?key=69
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 03-18-2010, 12:50 PM   #51
Rewards Points: 866
Good point that I hadn't thought of.
You bad - unfortunately not an unfair comment on the way the state wastes taxpayer money.
As for measuring amps w/o a load, I wondered about that but didn't know if some fancy modern equipment couldn't do it. I know my inexpensive little meter cannot.
Not sure, but it is easy enough to find out why he thought it was a 30 A line.
If he has a 30 A breaker isn't his a fire risk? It definitely is a 20 A receptacle. Whether or not the wiring is 12 or 10 who knows until they pop the receptacle out for a look.
Tags
determine rating , service panel
Wiring Main-Breaker Box in Detached Garage wstribl Electrical 15 05-11-2013 05:15 PM
wiring 100A to detached garage snowman Electrical 4 11-28-2009 04:53 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
Critique my wiring plan for my garage tigereye Electrical 10 03-24-2009 09:55 PM
