Wiring Garage 20 Amp - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2008, 03:56 PM   #1
wiring garage 20 amp
Got old AWG 12 G ungrounded wire running from 15A breaker to garage. Enters at the light switch, then branches off to a juction box. New wire (12-2 with ground) junctions with the ground on the edge of the box and goes into a small panel with 20 amp screw-lock fuses. Can 20 amp outlets be installed coming out of this panel?
fourempties is offline   Reply With Quote
Old 07-24-2008, 04:12 PM   #2
Rewards Points: 266
No. It is a 15 amp circuit. I really don't see what good the fuse box does....
junkcollector is offline   Reply With Quote
Old 07-25-2008, 08:29 AM   #3
So- is there a 15A twist fuse type box that I should put in there instead? Is there any harm in having 20A outlets installed to match the 20A fuse?
Old 07-25-2008, 10:15 AM   #4
Rewards Points: 174
Remove the fuse box and trash it. Then decide how many circuits you need in the garage. Install one or more circuits as needed (We can help you with that once you have decided how much power you need).
You will need to pull new cable to the garage. Once again we do not know what you need or want in the garage. Please think it over and let us know.
You can do a quick fix, would you prefer that?
Old 07-25-2008, 10:47 AM   #5
Ah- but the problem is, the garage is 50 feet behind the house and the wires are underground...
wiring detached garage ugabulldog Electrical 5 07-24-2008 04:13 PM
Enhancing existing wiring to detached garage justinperkins Electrical 46 07-07-2008 07:29 PM
Two Family Duplex - Garage Wiring Question Moonlight24 Electrical 2 06-22-2008 10:31 AM
Help with wiring a welder into garage. USOFFGRID Electrical 8 04-21-2008 01:02 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
