Wiring Fluorescenet Light Fitting - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 04:19 AM   #1
Wiring fluorescenet light fitting
Hello
Wonder if anyone can help.
I've just brought a flourescent light fitting. I want it to be connected to a cable for plugging into a standard socket, rather than fitted to a ceiling fitting.
Can anyone advice, what type of cable should I use and where should they come from on the block (shown with "?" on diagram. I am in Hong Kong, we use the British wiring standard.
I have attached a diagram of the set up, okay it's not the drawing standard of a Sparky but I think it covers everything.
If anyone can help, I'd be most grateful.
Many thanks
Josette
josette is offline   Reply With Quote
Old 03-06-2009, 08:22 AM   #2
joed's Avatar
Rewards Points: 13,332
All the ballasts we use in Canada have a drawing on them. It shows where to connect the line power.
Old 03-06-2009, 08:36 AM   #3
Rewards Points: 2,350
Originally Posted by josette View Post
Hello
Many thanks
Josette
Your English sounds like you are in the UK or Australia. So not many of us are familiar with the system and standards in place there. I can tell you where to put the wires, but what method of attachment is dependent on the local standards. Either way, you will need some sort of strain relief for the cord to keep it in place and avoid stress and abrasion on the conductors.
Get your self a 3-wire cord, brown, blue, and yellow/green. The blue wire attaches to the red terminal on the bottom in your drawing. The green/yellow attaches to the middle terminal, and the brown attaches to the top terminal.
Again, the electrical connection is important, but a secure mechanical connection is important too. Go to your local hardware and find a means to secure the cord mechanically to the light enclosure.
Old 03-07-2009, 01:00 AM   #4
Solved
Many thanks, that's done the trick.
All the best
josette
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Question with wiring up a flood light. SuperAkuma Electrical 6 09-20-2008 10:58 AM
Old wiring - Bathroom Light Psully24 Electrical 11 12-01-2007 12:20 AM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 06:25 PM
Help, the bakelite light fitting in my shower room smells! Unregistered Electrical 1 08-13-2004 07:03 AM
