Wiring Flood Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 08-26-2010, 08:52 AM   #1
Rewards Points: 274
wiring flood lights
About to wire new house for electrical. Can flood lights be motion and switch activated and also have it where you can turn off motion activation and only turn on w/ switch? Do I need to wire any different for motion versus just switch?? Thanks
ugabulldog is offline   Reply With Quote
Old 08-26-2010, 09:01 AM   #2
Anything can be done if you have the $$$$
macdonald is offline   Reply With Quote
Old 08-26-2010, 09:05 AM   #3
Licensed electrician
Rewards Points: 1,506
The switch can over-ride the motion sensor. If the switch is off the fixture will not work. The sensor needs power to see the motion.
Some MS lights will alllow a quick on-off-on to turn the light on for a short period.
Old 08-26-2010, 09:57 AM   #4
While I am sure this can be done with conventional wiring (and enough money), it is relatively simple with home automation systems such as Insteon (the one I use). No special wiring required.
oberkc is offline   Reply With Quote
Old 08-26-2010, 10:19 AM   #5
Rewards Points: 274
the reason i am asking is because the last house we built,...the electricina siad you can wire up for motion and use a switch only light, but you can't wire up for switch only and use motion later on.....I want the option of a motion light and want to wire for it now since it is much easier than later......if I need to do special wiring, if not then it obvioulsy doesn't matter at this point.....do I need to do different wiring for motion versus switch only lights is my question???
Old 08-26-2010, 10:32 AM   #6
Many fixture already have the motion sensor built in.
Wiring 2 Motion Sensor Flood Lights Through Siding Datwood2009 Electrical 3 05-15-2010 10:16 AM
Safely Wiring New Recessed Lights? Destin Electrical 3 03-17-2010 09:04 PM
Help with wiring two lights kjdement Electrical 3 09-25-2009 07:38 AM
Wiring Outlets Then Switch Then Lights heydj Electrical 9 05-07-2009 08:09 PM
Wiring lights on vaulted ceilings Unregistered Electrical 4 01-31-2008 09:39 PM
