Wiring Flood Light - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2013, 11:40 AM   #1
Wiring flood light
Hey men I unhooked this light but can't figure out how to rewire it so the on off switch works. I took it down while we were welding the awning up.
Kpack is offline   Reply With Quote
Old 07-14-2013, 11:41 AM   #2
Another pic
Old 07-14-2013, 11:43 AM   #3
More pic
Old 07-14-2013, 11:44 AM   #4
One more pic that goes to the switch. When i wire nut the three whites together and three blk together the bulbs burn fine but when I cut the switch off it kicks the breaker.
Old 07-14-2013, 01:39 PM   #5
As best I can tell from the pics...The white/black going to the switch is really just a long black that the switch is interrupting. The black coming out of the wall should go to that black on the switch, the white coming from the switch should go to the black on the light.
fj5gtx is offline   Reply With Quote
The Following User Says Thank You to fj5gtx For This Useful Post:
Kpack (07-14-2013)
Old 07-14-2013, 01:55 PM   #6
Thank you sir it works now. I couldn't figure that white back to the blk through the switch.
Old 07-14-2013, 01:59 PM   #7
Resi EC
Rewards Points: 252
backazzwards
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
The Following User Says Thank You to Gac66610 For This Useful Post:
Kpack (07-14-2013)
Old 07-14-2013, 02:07 PM   #8
Originally Posted by Gac66610 View Post
backazzwards
Does it matter which color actually feeds the switch?
Looks like the switch isn't grounded, considering that is the part you put your hand on often.
Kpack (07-14-2013)
Old 07-14-2013, 02:14 PM   #9
Resi EC
Rewards Points: 252
not really ... it does matter what color feeds the light
Kpack (07-14-2013)
Old 07-14-2013, 02:19 PM   #10
Resi EC
Rewards Points: 252
Should have one black wire and one white wire to tie the light to, if not you'll have twop white wires on the light.
replace the light, which white is neutral(grounded) and which comes from switch
I'm going to take my "not really" response back, I'd have to look it up, but I'm pretty sure it says on a switch loop (which you have) the white wire is only to be used to feed the switch
Kpack (07-14-2013)
Old 07-14-2013, 02:25 PM   #11
I tied the blk from the house to the black to the switch. The white from the switch to the blk on the light . Then the white from the house to the white on the light.
Old 07-14-2013, 02:45 PM   #12
Originally Posted by Kpack View Post
I tied the blk from the house to the black to the switch. The white from the switch to the blk on the light . Then the white from the house to the white on the switch.
Uh, no you didn't on that last sentence. You took the white from the house to the white on the LIGHT. Otherwise you'd blow the breaker again as soon as you closed the switch.
Is that switch/housing outdoor rated? If not, I'd replace it.
Kpack (07-14-2013)
Old 07-14-2013, 02:52 PM   #13
I edited that thanks said it wrong its been a long weekend.
Old 07-14-2013, 03:28 PM   #14
Resi EC
Rewards Points: 252
The black from the house should go the the white to the switch...
The white from house to white on fixture...
Black from switch to black on fixture...
Kpack (07-14-2013)
Old 07-14-2013, 03:50 PM   #15
Do I need to take it back apart and rewire it.
recessed light wiring in attic not to code robstalker Electrical 8 12-03-2012 05:15 PM
Ceiling fan light 3 way wiring problem Aurora64 Electrical 0 11-18-2012 08:19 AM
Light Wiring Question mataguri Electrical 4 11-09-2011 02:15 AM
Basic light wiring question speedster1 Electrical 3 11-29-2010 06:48 PM
bathroom light bar wiring kenny11876 Electrical 6 03-05-2007 06:25 PM
