Wiring Fan And Light Separate - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 11:31 PM   #1
wiring fan and light separate
Hi,
If I want to wire and light separate from the exhaust fan please let me know if I am correct. I run my 14/2 from the power source to first switch on a double rocker switch then I run a 14/3 black (fan) and red (light) from power out terminals to the fixture and connect 14/3 black to fan and 14/3 red to light?
mikem201 is offline   Reply With Quote
Old 03-08-2013, 11:45 PM   #2
Electrical Enthusiast
Rewards Points: 504
Yep, that should work.
Kyle_in_rure is offline   Reply With Quote
Old 03-08-2013, 11:46 PM   #3
Rewards Points: 6,652
Yep, you are correct. Does not matter which one goes where (Black or Red), just remember the color when you wire it up at the fan.
If this is for the bath, wire the exhaust light with the light over the vanity. I wished that I had done it that way, vs. listening to the wife who wanted a separate switch for the fan, and the two lights.
Old 03-08-2013, 11:50 PM   #4
Rewards Points: 83
yep red or black doesn't matter unless you care which switch controls the light or the fan
mech_gui is offline   Reply With Quote
Old 03-08-2013, 11:50 PM   #5
Rewards Points: 12,828
http://www.bing.com/images/search?q=...electedIndex=2
Old 03-08-2013, 11:54 PM   #6
Instead of a double rocker switch and I wanted to use 2 separate switches I wouldn't even need 14/3, correct? I could run 14/2 for both the light and fan. To get power to the second switch I would just pigtail off the power in to the first switch?
Old 03-08-2013, 11:54 PM   #7
Old 03-08-2013, 11:59 PM   #8
Rewards Points: 504
You would have to pigtail the hot wire with a wire nut to feed the two switches. You would still need 14/3 (or 2 14/2s) to operate the fan and light seperately.
Old 03-08-2013, 11:59 PM   #9
Rewards Points: 83
yep same principle just two devices
Old 03-09-2013, 12:03 AM   #10
So, I would pigtail off the power in at the first switch to power second separate switch? For a double rocker switch though I don't need to pig tail do I?
Old 03-09-2013, 12:06 AM   #11
Old 03-09-2013, 12:13 AM   #12
Rewards Points: 83
on two devices you pig tail the line in to the bottom terminal of each switch then the other two hots to the top terminal on the two 14s to the fan & light neutrals all tied together at switch & fan. That isolates the power to each device.
Old 03-09-2013, 08:38 AM   #13
Rewards Points: 2,512
Instead of a double rocker switch and I wanted to use 2 separate switches I wouldn't even need 14/3, correct? ?
You could use 3 conductor cable.
hammerlane is offline   Reply With Quote
Old 03-09-2013, 09:52 AM   #14
chitownken's Avatar
Rewards Points: 510
If you're going to use 2 switches, why not put a timer on the fan?
chitownken is offline   Reply With Quote
Old 03-09-2013, 09:54 AM   #15
Rewards Points: 83
and a vacancy sensor on the lights
