Wiring A Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 11-21-2012, 12:49 PM   #1
wiring a fan
my home wiring has 14/2 copper, black, white and red. but my hunter fan does not have a place for the red wire to go and i cant get the fan to work is the red wire my problem
swampthing is offline   Reply With Quote
Old 11-21-2012, 12:53 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
How is the switch wired?
How many wires in the ceiling box?
Where is the ground wire?
Where are you located?
Old 11-21-2012, 01:11 PM   #3
Rewards Points: 6,652
If you do not have a light kit, check the switch to see if the black or red is connected to the dimmer switch if there is one. If you have a light kit, there should be two hots, two neutrals.
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
