Wiring A Fan - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-01-2012, 09:25 PM   #16
Sparky
Rewards Points: 510
take the white wires apart, if the switch is 'on', do you have continuity between the white and black of the cable that is 'dead'?
Techy is offline   Reply With Quote
Old 06-01-2012, 09:29 PM   #17
No, it's dead with the switch on, like it's the one coming from the switch, since there is no power there.
ws450r is offline   Reply With Quote
Old 06-02-2012, 12:09 PM   #18
Sparky
Rewards Points: 510
Do you have a multimeter, or are you only using a non contact 'beep' tester?
Old 06-02-2012, 01:26 PM   #19
Its a multimeter
Old 06-02-2012, 02:20 PM   #20
Sparky
Rewards Points: 510
Put the multimeter on the 'ohms' setting, turn the switch on, and measure between the black and white that do not have power.
Old 06-02-2012, 03:44 PM   #21
I figured it out. I hooked the black and blue fan wires up to the hot black wire and connected the white fan wire to the dead black. Everything works just fine, fan and lights.
Old 06-02-2012, 06:38 PM   #22
Sparky
Rewards Points: 510
The only possible way for that to be true is if you're switching the neutral conductor, instead of the hot. which would explain why the switch shows no power.
Old 06-02-2012, 07:35 PM   #23
Licensed electrician
Rewards Points: 1,016
It may be working but something is not correct. The white from the fan should not be connected to the black.
Old 06-02-2012, 08:22 PM   #24
I wont disagree, but the black that the white from the fan is hooked to is dead with and without the switch on.
Old 06-02-2012, 08:49 PM   #25
Sparky
Rewards Points: 510
The only thing i can come up with is a switch loop with a switched neutral.
the 'hot' cable's black should be hooked to the 'dead' cable's white, then the remaining black/white should go to the fan
The Following User Says Thank You to Techy For This Useful Post:
k_buz (06-02-2012)
Old 06-02-2012, 10:16 PM   #26
dmxtothemax's Avatar
Rewards Points: 5,096
Most people would guess that those other wires are a switch loop !
Either it is not, or it is, and is faulty.
You need to investigate those other wires more !
Can you follow them ?
dmxtothemax is offline   Reply With Quote
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 09:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
