Wiring An Extractor Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 01:00 PM   #1
Wiring an extractor fan
First post. Please be gentle.
I'm replacing a Punto Vortice M90 extractor fan with another Punto Vortice M90 extractor fan. When I switched off the electrics and unscrewed the cover, I noticed the old fan has a circuit board that the new one doesn't. I assume this is because the old one could be used with a timer (though it wasn't). We don't need a timer on the new one, and there is no circuit board on it.
The wiring from the ceiling has a blue wire and a yellow wire which were connected to the old unit via a connector strip, and a red wire, which wasn't connected to anything (no bare wire exposed). All the new unit has is two black wires, both of which are inserted into a connector strip. Does it matter which black wire connects with the blue wire, and which with the yellow, via the connector strip?
Sir_Hamster is offline   Reply With Quote
Old 11-06-2011, 01:12 PM   #2
Code05's Avatar
Rewards Points: 1,104
Are you in the UK by chance?
Code05 is offline   Reply With Quote
Old 11-06-2011, 01:20 PM   #3
Code05's Avatar
Here is a manual for your model I think. Pg 64 and 65 show connections.
http://www.vortice.info/documents/Punto_pose.pdf
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 08:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 03:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 11:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
