Wiring An Exterior Covered Patio Area??? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-18-2008, 10:21 PM   #1
Get er done
Wiring an exterior covered patio area???
I extended out on my house to make a large covered area over my patio. It has a roof with attic space, and is not enclosed with walls. I plan on installing several recessed lights, outlets and a fan. since it is not enclosed and heated will I be able to use regular 12/2 electrical wire, J-boxes, lights, fan, etc?
kbrena is offline   Reply With Quote
Old 07-18-2008, 11:15 PM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Partially as long as you don't expose the nm-b to the elements. Your device boxes will need to be weatherproof and you will need emt conduit sleeves as protection for your drops to receptacle boxes and switches.
Old 07-18-2008, 11:42 PM   #3
Get er done
Thanks for responding, What is nm-b?
Old 07-18-2008, 11:44 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Romex... nonmetallic sheathed cable like inside your home. You also need a bushing where you enter the emt with the cable for abrasion reasons.
slumped patio fix ?? houser Building & Construction 5 03-18-2010 06:25 AM
Concrete Patio drainage problem lakekids Building & Construction 5 07-17-2008 05:27 AM
Flat Roof Leak (used as patio above living area) brutter Roofing/Siding 4 04-13-2008 09:11 PM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 10:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
