Wiring On Exposed Wood Beams - Ontario Canada - Electrical - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 10:02 PM   #1
Wiring on exposed wood beams - Ontario Canada
I'm renovating part of my house and i have opened up the main floor ceiling to create cathedral ceilings, and I have replaced the original cross beams which supported the old ceiling. These are new 6" x 6" beams about 94" above the floor surface, if that makes any difference, and I want to run some new 14/2 lighting wiring along the tops of these beams, then through the thickness of the beams to a couple of octagonal junction boxes set into the bottom face of the beams for light fixtures. Does the wiring running along the top side of the beam require a conduit or can it simply stapled to the beam where it is exposed?
djgap is offline   Reply With Quote
Old 08-04-2010, 10:09 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
I would put it in conduit as it will simply look better, but not sure what code says. I think romex is ok unprotected if it's at a height where nothing can damage it.
Old 08-05-2010, 07:08 AM   #3
57_Hemi's Avatar
Ya, if ur going to see the wire run than I would surely run it in conduit.....looks much nicer....
Im not sure exactly what code states regarding wire fastening but if you think about some attic spaces you'll see wires running thu out and those are considered accessible areas (well some of them are atleast). in this case no one will be able to walk on top of your support beams (lol) so Im pretty sure you'll be able to run the wire along top without conduit and with only a few staples just to keep things secure.
(I cant remember if it was a max of 24 or 36 inches per fastener in attics......hmmm)
but im sure someone else here will be able to give u a better answer to ur question....
good luck !!
57_Hemi is offline   Reply With Quote
Old 08-05-2010, 09:16 AM   #4
If they are on top of the beams I doubt anyoner will see them
A friend has a cabin on a lake, they ran the wiring on top of the beam
Old 08-05-2010, 12:26 PM   #5
the wiring would not be visible from the floor.. unless of course you are 7'6" tall...
Old 09-29-2010, 12:41 PM   #6
Paul
Ontario Electrical Safety Code Rule 12-518 is for exposed wires on a wall, put I think it would apply in your situation; rule states that if cable within 1.5 m from floor it must be protected. Your cable is well above the 1.5 m mark and should not require protection.
finalsay.ca is offline   Reply With Quote
Exposed Alarm system wiring? Grimm Electrical 8 04-20-2010 01:16 PM
Electrical wiring exposed....problem or not?? pipsal Electrical 4 03-22-2010 11:49 AM
help with forced air wood add on wiring? humboldt HVAC 4 03-05-2010 06:20 AM
Newbie from Ontario, Canada rod46 Introductions 2 01-30-2010 10:31 AM
Exposed dishwasher wiring secutanudu Electrical 15 04-20-2009 10:44 AM
