Wiring From Existing Panel To New Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2009, 09:59 PM   #1
wiring from existing panel to new garage
hi i am adding a new garage to the side of my existing unit. i will put a new subpanel in the new structure and wire it to the existing main panel on the opposite wall of the existing garage. the wiring will go up the wall and accross the rafters of the old garage through a non accessable attic and down the common wall to the new subpanel. my question is can i just run 4 separate wires between the panels or do they need to be in conduit or do i need to use a romex type cable. i have another subpanel under the house and the electrician just ran 4 separate wires with no conduit so i was wondering if this is ok or not. thanks for any help.
al99m is offline   Reply With Quote
Old 07-29-2009, 08:11 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 480
First off the sub panel under the house is a code violation!!!
Any wiring in a home needs to be a cable, or wired in some kind of raceway!
jbfan is online now   Reply With Quote
Old 07-29-2009, 11:06 AM   #3
yeah thats what i thought too but thats the way the house was wired when they added the sub box for a double oven. so i guess i will go back and put the wires in conduit. thanks
Old 07-29-2009, 02:55 PM   #4
Sub panel
Is this an actual subpanel under the house or simply a 1900 or similar box?
angrysmileyface is offline   Reply With Quote
Old 07-29-2009, 06:01 PM   #5
Cable is fine for your installation, but.............a panel under the house?
Nice
220/221 is offline   Reply With Quote
Old 07-29-2009, 07:22 PM   #6
jbfan's Avatar
Rewards Points: 480
Nice
I have seen my share in crawl spaces for the under floor furnance.
Old 07-29-2009, 07:52 PM   #7
actually the house is built on a hill so there is room to walk under the house so the panel is acessable
Old 07-29-2009, 08:40 PM   #8
That's where mine was at the last house
Luckily right by the bulk head so I dug an area out
That way you could walk right by the furnace near the bulkhead
Old 07-29-2009, 08:42 PM   #9
I just noticed this
If these are 4 separate wires to FEED the subpanel then they MUST be in conduit. If they are a cable then that is OK
Anyone else???
wiring 220 into sub panel danma Electrical 4 07-28-2009 10:28 AM
rewiring garage - adding sub panel wombosi Electrical 3 05-28-2009 10:08 PM
Sub panel wiring question mntnvew Electrical 13 03-02-2009 11:28 AM
Wiring a garage scrayzee21 Electrical 10 10-14-2008 03:46 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 07:37 AM
