Old 06-29-2010, 10:09 AM   #1
Wiring Exhaust Fans
I have 2 bathrooms in which I have to replace exhaust fans. The bathrooms are close in the house, and share an attic access (or they are close enough). I'm wondering if I can use one power source and connect each fan (I guess I would be splicing a wire from the power source to each fan) or if this would somehow result in less power to each. Intuition tells me it should be fine--like connecting 2 lights to the same source. Lack of experience tells me I should ask.... thanks for any help.
Chrisatola
chrisatola is offline   Reply With Quote
Old 06-29-2010, 10:13 AM   #2
Wiring Exhaust Fans
A shared circuit would work if these are standard exhaust fans. If they are the fan/heater combo type then you would need a dedicated circuit for each fan.
teamo is offline   Reply With Quote
Old 06-29-2010, 10:28 AM   #3
J. V.'s Avatar
Wiring Exhaust Fans
Deleted. Wrong information.
Old 06-29-2010, 10:41 AM   #4
Xtreme DIY'r
Wiring Exhaust Fans
Originally Posted by J. V. View Post
Bathrooms should have one 20 amp circuit per bathroom. This is an NEC requirement for new construction
Did this change somehow ?
One 20a circuit that feeds erverything in ONE bathroom
OR
One 20a circuits that feeds outlets only in multiple bathrooms
Myself I prefer one 20a to outlets only in each bathroom
What circuit are you tapping into to power these ?
What is already on that circuit ?
Will each have its own vent path ?
Old 06-30-2010, 11:09 AM   #5
J. V.'s Avatar
Wiring Exhaust Fans
OR
Dave, Nothing has changed as far as I know. Let me double check and see what the requirement is. Thanks for catching it.
Old 06-30-2010, 11:18 AM   #6
joed's Avatar
Wiring Exhaust Fans
The 20 amp per bathroom only applies to receptacles. Lights and fans can be on any circuit.
Do not PM with questions that can be asked in a forum. I will not respond.
Best way to test wiring prior to installing ceiling fans Troglodyte Electrical 9 05-24-2010 07:26 PM
Need wiring help with a bathroom exhaust fan Brieninsac Electrical 3 04-16-2010 01:06 PM
New wiring and switch for bathroom exhaust fan looking4help75 Electrical 9 06-27-2008 05:15 PM
Recommendation: new exhaust fans in basement Tom's Diner HVAC 10 05-04-2008 09:58 PM
Multiple bathroom exhaust fans dpreznik HVAC 17 08-30-2007 01:09 PM
