-   -   Wiring Exhaust Fans (http://www.diychatroom.com/f18/wiring-exhaust-fans-74944/)
chrisatola 06-29-2010 10:09 AM
Wiring Exhaust Fans
I have 2 bathrooms in which I have to replace exhaust fans. The bathrooms are close in the house, and share an attic access (or they are close enough). I'm wondering if I can use one power source and connect each fan (I guess I would be splicing a wire from the power source to each fan) or if this would somehow result in less power to each. Intuition tells me it should be fine--like connecting 2 lights to the same source. Lack of experience tells me I should ask.... thanks for any help.
Chrisatola
teamo 06-29-2010 10:13 AM
A shared circuit would work if these are standard exhaust fans. If they are the fan/heater combo type then you would need a dedicated circuit for each fan.
J. V. 06-29-2010 10:28 AM
Deleted. Wrong information.
Scuba_Dave 06-29-2010 10:41 AM
Originally Posted by J. V. (Post 462895)
Bathrooms should have one 20 amp circuit per bathroom. This is an NEC requirement for new construction
Did this change somehow ?
One 20a circuit that feeds erverything in ONE bathroom
OR
One 20a circuits that feeds outlets only in multiple bathrooms
Myself I prefer one 20a to outlets only in each bathroom
What circuit are you tapping into to power these ?
What is already on that circuit ?
Will each have its own vent path ?
J. V. 06-30-2010 11:09 AM
OR
Dave, Nothing has changed as far as I know. Let me double check and see what the requirement is. Thanks for catching it. :thumbsup:
joed 06-30-2010 11:18 AM
The 20 amp per bathroom only applies to receptacles. Lights and fans can be on any circuit.
