Wiring For A Exhaust Fan/light On 1 Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 10:53 AM   #1
wiring for a exhaust fan/light on 1 switch
I have run 12/2 from box to a switch then 12/2 up to the fan/light the fan/light has a black/white/red/copper wires , i can turn the fan and light on and it works but........the problem is when i turn it off it blows the breaker . Is there a way to make this work without running another wire ? Thanks dunebuggy4
dunebuggy4 is offline   Reply With Quote
Old 06-28-2011, 01:10 PM   #2
Rewards Points: 516
Your description is not that clear.
I am guessing an educated guess. Copper (bare) is the ground. Join it at light/fan box to ground screw (green?). Twist white light/fan wire to white wire from switch and cap. Twist black and red light/fan wires together and then twist to black from switch and cap.
Switch box: Hot Black "from box" goes to one screw terminal or insert on switch. Black from light/fan goes to other screw terminal or insert on switch. Both whites in switch box do not go on switch. They twist together and cap.
If switch has grounding screw, ground it from surplus bare copper. If switch has more than 2 terminals, you've got the wrong switch.
diyorpay is offline   Reply With Quote
Old 06-29-2011, 03:42 AM   #3
Thanks for reply
diyorpay you are right about the copper wire , i will try this right after work and again thanks . dunebuggy4
Old 06-29-2011, 06:38 AM   #4
Not getting the full story. Fan/light should have 4 wires, black is fan hot, red is light hot, white is neutral, bare or green is ground. If running the fan and light from one switch leg, twist the black/red together with the switch leg. For two switches, one each switch leg to each fan wire.....sw1 to black, sw2 to red. Always neutral to neutral and ground to ground.
Old 06-29-2011, 07:23 AM   #5
2 white wires
I am sorry for bad description ( 1st time ) i forgot to say the fan has black/white and the light has red/white wires and then one bare copper wire , and i have 12/2 wire coming from switch 1 white/black/bare copper wire . I will try this after work and let you know , thanks for all the info . Thanks dunebuggy4
Old 06-30-2011, 03:44 AM   #6
finished
Thanks for the help the info i got on this site got me through . Thanks again dunebuggy4
Double switch wiring rockclimber Electrical 18 03-18-2012 10:13 PM
Need help wiring bathroom light/exhaust fan unit on one switch. nailliK Electrical 13 04-20-2011 07:17 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 02:44 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 01:23 PM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 07:47 PM
