Wiring For An Electric Tankless Water Heater - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-23-2012, 03:30 PM   #31
Or if you switch to natural gas because its so cheap now any, why not go with a high efficiency AO Smith Vertex water heater. Just about everything you get with tankless (10 minute heat time from ambient) in a conventional sized unit. You can't run these out of hot water. No "cold water sandwich" issues like tankless either.
DIY install is same difficulty as a standard WH.
http://www.hotwater.com/water-heater...ex/power-vent/
kwilcox is offline   Reply With Quote
The Following User Says Thank You to kwilcox For This Useful Post:
Missouri Bound (07-23-2012)
Old 07-23-2012, 03:45 PM   #32
JOATMON
ddawg16's Avatar
Rewards Points: 1,958
I have to concure with gas tank over electric tankless. Even a gas tank heater is cheaper overall than a gas tankless. When you factor in the payback on a gas tankless....about the time you get into the payback....it's pretty much at the end of it's life.
Gas vs electric? No comparison.....
If it's instant hot water you want...then look into recirc systems....
Hard to beat a gas water heater for simplicity and reliability.
Old 07-23-2012, 03:57 PM   #33
Missouri Bound's Avatar
Originally Posted by ddawg16 View Post
I have to concure with gas tank over electric tankless. Even a gas tank heater is cheaper overall than a gas tankless. When you factor in the payback on a gas tankless....about the time you get into the payback.....
And one of the selling points of the tankless is that it doesn't have to "continually" heat the stored water. Well, tank heaters do not either. Once a tank is brought up to operating temperature, the newer tanks are so well insulated that the do not operate unless a substancial amount of hot water is used. And I do know this first hand. When I replaced my hot water boiler, the gas supply was shut off to the water heater as well. 8 hours later when I relit the water heater, it didn't fire up. Turns out that it can easily sit for 8 hours and maintain the temperature without "continually" firing as the tankless advertisements would lead you to believe.
Do you want it your way or the right way?
The Following 2 Users Say Thank You to Missouri Bound For This Useful Post:
ddawg16 (07-23-2012), stickboy1375 (07-23-2012)
Old 07-23-2012, 04:20 PM   #34
Rewards Points: 268
Agreed... We have a 50 gallon gas fired direct vent water heater and when no hot water is being used it seems to cycle about once every 6-8 hours. Not bad for 8 years old IMO.
I researched the tankless gas heaters too because I was sure they were the greatest things ever... After all the reading and skimming threads on here, I think a unit very similar to what I have will be installed when the time comes.
Marqed97 is offline   Reply With Quote
Old 07-23-2012, 08:56 PM   #35
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
W use a tankless water heater 28.8kw model and it's great we have had it about ten years. But you should really know what's going on when you install one. And check with the warranty whether it's covered in a DIY install. And POCO really like to know that you have one installed to make sure that the transformer can handle it without a lot of flickering lights.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 07-25-2012, 08:38 PM   #36
Rewards Points: 348
Here is a pic of my Rinnai DIY install. Local plumbing company quoted me $1900 to replace a 75 gallon power-vent gas HWT. Got this from Amazon for $850. Another $200 in supplies and vent pipe and a Saturday and I was good to go.
Edit: Not sure why pic went sideways. Heater is installed vertically.
herdfan is offline   Reply With Quote
Old 07-25-2012, 08:43 PM   #37
You installed it sideways??
Old 07-26-2012, 07:19 PM   #38
Where's the drip leg for that gas line?
Old 07-26-2012, 07:46 PM   #39
Rewards Points: 348
It's there. That bottom fitting is a tee.
The Following User Says Thank You to herdfan For This Useful Post:
kwilcox (07-26-2012)
Old 07-26-2012, 10:20 PM   #40
I installed an LP tankless water heater for my folks. Pretty easy with the right amount of research ahead of time. Went from electric to LP and they are saving about 50-60 bucks a month in Electric costs alone.
kmk7110 is offline   Reply With Quote
Old 07-26-2012, 10:29 PM   #41
How many people in the house? That seems extremely high for just a water heater.
Water heater - Gas or Electric Sartrean Appliances 17 01-13-2012 04:45 PM
elevate electric water heater? crankbait09 Plumbing 18 04-18-2011 11:35 AM
Wiring tankless hot water heater Jarrod3154 Electrical 8 02-26-2011 12:34 PM
Wiring to a water heater bvsmith_1974 Electrical 3 09-03-2008 03:32 AM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
