-   -   wiring an electric receptacle (http://www.diychatroom.com/f18/wiring-electric-receptacle-280/)
Jonathan_in_KY 01-01-2005 04:05 PM
I have 1 wire hanging in my basement. It goes to the breaker box.(it is romex with 3 wires) I have purchased an outlet that I would like to connect to the lone wire but have never connected one and want to make sure my understanding of how to do it is correct before I go any further.
The receptacle I have has 2, 3 prong outlets on it.
On the left and right sides of the outlet there are 2 screws, as well as 1 other screw on the bottom left that has a green head.
I think that I am to put the hot wire on the side marked hot, and the other wire on the "white" side. That leaves the third and last wire. This wire has no insulation on it, I am assuming that it goes on the green screw.
Am I correct in assuming that this is how this is done? (with the power shut off of course!)
Thank you for any and all helpful replies.
Neil_K 01-03-2005 08:43 AM
The uninsulated one is the ground that goes on the green screw.
Hammertime 01-05-2005 09:28 AM
You're exactly right. The hot side is the side that has the two screws on it and the other side is the neutral(white) side which has the 3rd screw for the ground. The ground screw is usually always on the side of the neutral.
