Wiring Electric Range - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 11:14 AM   #1
Getting a new range and decided to install outlet prior to arrival so that the plug wire can be attached and ready to go. The current range is hard wired with 300v to ground, Type SE cable, Style U Type RH, 3 wire (Red/Black/bare) 8 guage AL. Made sure the outlet I purchased was AL compatible. Stopped when I saw that the bare wire was used as the neutral. Older post indicated that the bare wire in SE wire could be used for current load. Can this wire be used or is a new feed required.
Thanks for your help,
Phil
Ringo2 is offline   Reply With Quote
Old 05-23-2011, 11:17 AM   #2
Civil Engineer
Rewards Points: 4,770
What country are you located in that has 300V to ground outlets?
Daniel Holzman is online now   Reply With Quote
Old 05-23-2011, 11:30 AM   #3
Licensed electrician
Rewards Points: 1,612
That is the insulation rating on the cable, not the voltage.
Old 05-23-2011, 03:27 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,938
Phil
As I recall, it has never been acceptable to use a bare conductor as a neutral/ground in a 3-wire circuit. Back when this type of circuit was allowed, the grounded/grounding conductor had to be insulated.
EDIT: 250.140(3) allowed the bare conductor in SE cable (but not other types of cable) to be used as a current carrying conductor in these circuits.
mpoulton is offline   Reply With Quote
Old 05-23-2011, 03:44 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Completely opposite. The neutral in SEU cable was allowed to be used for older range circuits.
Old 05-23-2011, 05:14 PM   #6
Speedy Petey, you were in the post from 2008 that I read this morning saying the same thing -"The neutral in SEU cable was allowed to be used for older range circuits." I wrote the post b/c to be sure if the wire in my 1971 house would be the acceptable SE type. So, can I install the outlet using what I have or need to run a new feed line (which would quite a task)?
Thanks for all the replies,
Phil
Old 05-23-2011, 05:49 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
Phil
I'm not Speedy Petey, but I will answer for you.
As long as you are not relocating the circuit, then you can continue to use this wire.
jbfan is online now   Reply With Quote
120v gas range wiring question Redfishjoe Electrical 5 05-11-2011 09:37 PM
Electric Range Breaker Size mkeehn64 Electrical 0 03-21-2011 08:46 AM
Electric to gas range Manis Appliances 9 02-01-2011 02:24 PM
Range hood wiring needs tweaking RedHelix Electrical 4 12-02-2010 01:31 PM
thermostat wiring for electric heater Captflx HVAC 3 03-05-2010 08:48 PM
