Old 06-16-2005, 10:10 PM   #1
Question
Wiring from electric motor
Hello All. could someone please tell me if i can wire a 1/2 hp elec. Exhaust fan motor with a plug such as a Dryer Pigtail direct to the motor so i can use the 220 side instead of hard wiring to the supply source ? thanks for any info. subman
Submarineman is offline   Reply With Quote
Old 06-17-2005, 01:50 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
It is physically possible, but I don't know if code would allow it. Please check with your Building Inspection Department for local electrical code.
If I'm not mistaken, a modern code 4-wire dryer plug has two hots, a neutral and a ground wire, but a motor in the 220 mode has only two hots and a ground.
(I'm not a pro electrician, just a long-time DIYer.)
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 10:40 PM
Electric Range Wiring manhattan42 Electrical 11 07-05-2006 06:03 PM
Wiring from electric motor subman Electrical 1 06-24-2005 11:37 PM
