Wiring Electric Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 10:31 PM   #1
Rewards Points: 113
wiring electric heater
I have a 240V, 30 amp receptacle in garage. I want to ceiling mount a 240 electric heater ( draw of 21 amps) and plug it into the current recepticle. Can I have the wire from plug to heater secured to wall without code violation? If it is a violation, what must I do to connect heater to circuit and meet/pass code?
Captflx is offline   Reply With Quote
Old 01-11-2010, 07:20 AM   #2
Remodeling Contractor
The cord from the heater must be less than 6'
Old 01-11-2010, 12:53 PM   #3
Rewards Points: 113
O.K. then I plan to run a new line to a ceiling junction box and then run a wire to the heater. Must I use separate wires ( no cover/jacket) inside a metal flex-conduit for this short distance? For the 3 ft distance from box to heater, can I run the jacket/covered wire without a conduit?
Old 01-11-2010, 03:45 PM   #4
no separate wires to be used. From the junction box to the heater use flex or AC or SO rubber cord.
Old 01-11-2010, 09:15 PM   #5
Rewards Points: 113
Thanks for your help Bob.
Old 01-12-2010, 12:15 AM   #6
" Euro " electrician
frenchelectrican's Avatar
Just make sure you are aware with conductor size you will need 6.0mm { 10 AWG } if you going to use the 6.0mmX3 { 10 -3 } SO or simuair cord you will have to remark the white conductor with tape or marker so you know you are on 240 volts.
And the other thing keep in your mind the cords count is diffrent than standard building cables { NM or UF,. etc }
The cords will count all conductors while the building conductors useally count the line et netural conductors but usealy not the EGC unless it marked.
Merci,Marc
Trouble With Electric Hot Water Heater whitedavidp Plumbing 8 04-22-2009 05:16 PM
Trouble With Electric Hot Water Heater whitedavidp Appliances 12 04-06-2009 06:47 PM
Trouble With Electric Hot Water Heater whitedavidp Electrical 7 04-06-2009 04:26 PM
Should i go from GAS to Total Electric HVAC & Water heater? ehoez HVAC 9 04-06-2009 08:57 AM
Wiring tankless water heater TheBossQ Electrical 4 07-11-2008 12:05 PM
