#1 |
wiring electric cooktop 4 wires to 3 wires
Have a new whirlpool G7CE3055 cooktop with 4 wires (black, red, white, bare) and 3 wire junction box (black, white, bare). Instruction say to wire black to black, Red to red, and cooktop white & bare to bare. The problems is that I don't have red at the junction box. what now?
#2 |
You may not wire it up at all until you run a new cable up from the panel with white neutral, red and black for 240 volt hot, and bare or green for ground.
Most likely the white and black feed wires in the box are 240 volt hots in y our situation. Ground (bare) may not be used as neutral.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. Last edited by AllanJ; 06-29-2011 at 08:40 PM. |
#3 |
Licensed electrician
Your old unit must have been 240 volt only. The new unit has both 120 and 240 volt components.
Answers based on the National Electrical Code. Local amendments may apply. Check with your local building officials. |
| The Following User Says Thank You to Jim Port For This Useful Post: | 1234mom (06-29-2011) |
#4 |
can the cooktop safely be wired with the black to black, white(junction box) to red(cooktop), and bare(junction box to white&bare(cooktop)?
#5 | |
wiring electric cooktop 4 wires to 3 wiresQuote:
#6 |
Electrical Contractor
Can you post a picture of the wires in your junction box?
-KB Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
wiring electric cooktop 4 wires to 3 wires |
#8 | |
#9 |
Semi-Pro Electro-Geek
It will function normally, and be unsafe. That's a code violation for good reason. The bare ground wire would be carrying current during normal operation.
#10 |
what mpoulton said.
#11 |
do all new cooktops have 4 wires? the old unit had only 3 wires and thus was hooked up to the 3 wires from the junction box just fine. Why does this new unit now have 4 wires when it is just a newer version of the old one? And why does the mfg. instructions allow for connection to a 3 wire box? The problem, again, that I ran into and was confused about was the fact that I had no set of reds to connect? What do the colors of the wires mean? Finally, I'm in Alabama and how do I go about finding a licensed electrician that I can trust to run a new power supply from my breaker box?
#12 |
#13 |
#14 | |
#15 |
Depending on the specific cooktop, the previous version may not have required a neutral. Some do, some don't. In the olden days, a three wire connection with an INSULATED neutral was used for stoves and dryers. That old-fashioned connection did not have a ground, and the metal case of the appliance was connected to the insulated neutral instead. This posed a major problem if the neutral connection ever became loose - the metal appliance itself would be electrified. That's why this is no longer allowed for new installations. It was never permissible to use an uninsulated grounding conductor as a neutral, which your prior cooktop may have.
| Display Modes | |
| wiring a receptical with 3 wires? | mac16m83 | Electrical | 3 | 04-11-2011 08:47 AM |
| Electric Cooktop too slow to heat | coachgns | Appliances | 1 | 02-05-2011 04:45 PM |
| Changing 220V to 110V (hardwired) for an electric to gas cooktop switch. | charleyhart | Electrical | 14 | 01-15-2011 02:12 AM |
| Electric door strike wiring help | z32 | Electrical | 3 | 03-22-2010 01:17 PM |
| Wiring from electric motor | subman | Electrical | 1 | 06-24-2005 11:37 PM |
