Wiring For A Dryer - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2006, 09:11 AM   #1
wiring for a dryer
i moved into a new house this weekend and put a new dryer outlet in to match the male end of the cord.
the dryer works, and tumbles, but doesnt get very hot. i was wondering if i didnt wire it correctly, if the dryer would get power, but not get very hot...or would it just not work at all.
thanks!
irish_hood is offline   Reply With Quote
Old 01-09-2006, 09:42 AM   #2
I'm guessing you are wired correctly. feel the back of the dryer. If that is real hot you may not have an adequate vent or it might be restricted.HS..
K2eoj is offline   Reply With Quote
Old 01-09-2006, 08:18 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
You did it backwards. You must match the cord to the wall receptacle, not the other way around.
I suspect you have it miswired and are only getting 120v to the heater.
Can you explain exactly what you have and how it is wired?
Old 01-11-2006, 12:28 PM   #4
you are right on pete.....i had one of the hots switched with the neutral (the red switched with the white), so i was only getting 120...i made the switch and it is working great.
thanks for your help!
Old 01-11-2006, 01:27 PM   #5
oh...and i didnt replace the outlet to match the plug...there was no outlet, just a pre-wired box. otherwsie, replacing the plug would have been the way i would have gone.
Wiring a 220v dryer receptacle pjpjpjpj Electrical 8 06-05-2007 04:08 PM
Problem with ELECTRIC DRYER plugs SpaceCrawler Appliances 6 06-03-2007 10:21 AM
Dryer wiring jasjks Electrical 8 09-11-2006 04:33 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
