Wiring Driveway Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 08:59 AM   #1
Cape Cod, MA
Rewards Points: 81
Hey guys,
I had a question about wiring some driveway lighting. At some point the previous owner of the house removed some lighting for the driveway and just closed the breaker and cut the wiring going to outside the house so the wiring is coiled up in the house with the light switch in the off position. I would like to re-install the wiring. I live in Massachusetts and Ive been told that to install the wiring by code it must go to a weather tight GFCI outlet that needs to be mounted to the house, then go down into the ground in plastic conduit with 20 amp UF cable then to the driveway light? Is this correct?
Thanks!
capecodder is offline   Reply With Quote
Old 03-06-2012, 09:16 AM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would install a GFCI weather tight box with an in use cover and install some conduit with an elbow to get you 12" below grade then run it to all your lights. But low voltage lighting may be a less expensive option.
Also check whether or not you need a permit.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-06-2012, 11:27 AM   #3
Rewards Points: 204
You do not need to GFCI protect outdoor lighting circuits in general. However. Depending on where the fixtures are located, it would be a good idea to use GFCI protection in some instances. If the lights are above the driveway on poles or mounted to the building they do not need GFCI. If they are at ground level I would use it even though I pretty sure you don't need it.
I would not use UF cable. I would use conduit all the way. Remember. The conduit must not be "subject to physical damage". Are you pulling a permit? If you do, you can rest assured your job will be safe. So pull a permit.
Old 03-06-2012, 11:48 AM   #4
Cape Cod, MA
Rewards Points: 81
Thanks for the input guys. I was under the impression that all outdoor circuits required a GFCI. Will I be able to install regular cable in the conduit? I thought UF cable was required for outdoor installations?
Thanks!
Old 03-06-2012, 08:36 PM   #5
Julius793's Avatar
Thanks!
UF if theres no conduit, once there is conduit anything that's rated for wet location if fine.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
General design and lighting? mrs1885 Landscaping & Lawn Care 14 01-06-2011 03:12 PM
Before I close walls: hard wiring under cabinet lighting with Romex. jws3 Electrical 6 08-29-2009 12:24 PM
Recessed lighting wiring? Kriv Electrical 2 10-17-2006 02:21 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 02:55 PM
