Wiring For Dock - Electrical - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 08:33 AM   #1
Wiring for Dock
I have a friend whose dock power is not working. I have found a dead short between the GFCI recepticle box and the service panel in the basement. Whoever did the wiring before used romex wire and just stapled it under the steps w/no conduit. I am planning on replacing the run w/ 10-2 UF-B.
Is there any code specifying how to staple the wire under the steps? I.E. distance protection etc.. I know that wiring through a studded wall requires metal protection from nails, screws, etc, but is there a similar code for outdoor steps? Also, I am not planning on using conduit under the steps, since I am using UF, is this OK?
Thx
B
bradleypeay is offline   Reply With Quote
Old 07-10-2012, 08:40 AM   #2
Rewards Points: 6,652
It has to be protected. I would probably use Conduit over UF. Reason being, is that it is easier to put in a splice box for THHN/THWN, than trying to keep a UF splice dry. Plus looks cleaner.
Old 07-10-2012, 06:36 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Thx
B
Just an opinion here, but I would GFCI protect the entire circuit to protect your butt since this hookup involves a body of water.
Old 07-10-2012, 06:39 PM   #4
E2 Electrician
Just curious, but protected from what under stairs? UF only needs to be protected where subject to physical damage, I just don't see that in the OP's UF location.
Old 07-10-2012, 06:42 PM   #5
Master Electrician
might be safer to put a gfci breaker in.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Help with wiring issues on a newly purchased house ThatGuy Electrical 13 01-17-2012 11:51 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 10:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 10:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 07:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 08:52 PM
