Wiring A Distant Pump - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-20-2013, 10:19 PM   #16
Rewards Points: 6,652
It is not a price quote. It is a arbitrary number, going with the largest sized cable that you have to run, which would be the 2/0. As for running to the garage, yes I would suggest using conduit from the house to the garage, so later on if ever have a problem, then you can pull new cable through.
Only problem is, the larger the cable, the harder it is to pull through conduit, and usually have to use a winch or ratchet puller, to pull the rope, attached to the cables, to get them through. Also have to have at least a 5 gallon bucket of pull grease. Not the most fun thing to do in life.
Once you get to the garage, then you can pull to the pump, but still would need a drawing of your land, showing distance from house to garage, then garage to pond, or place that the pump will be, along with service at the house, and service you plan on putting in place at the garage.
Use the calculator link I posted, it will give you an idea of what is the best route to go with, determined on the distance from the garage, if less than from the house.
Old 04-20-2013, 10:20 PM   #17
Rewards Points: 14
Originally Posted by gregzoll View Post
You can use the cartridge style fuses, which are used for heavy loads, but the old Edison fuses, you cannot. Even with Cartridge fuses, people place 1/2" or 3/8" copper pipe with the ends flattened in the fuse holder. With the old Edison's, people would just place a Penny in the socket, or even some have placed light bulbs in place of a fuse.
It is not that they no longer can be used, it is just that the code has changed over the years, and because breakers have a quicker trip response than fuses, is why you have seen the change over the years.
Now I understand. People will do some stupid things. I think all of my plumbing, septic and electrical was installed by some old farmer with a backhoe but no knowledge of any of those things. I have found some pretty weird stuff here that needs to be addressed. That's why I am on this forum - I want to be able to do some things on my own, but I want them done safely. I'm not as concerned about current code - just that it be safe. Of course, I understand that you guys can't actually recommend things that don't meet code.
Dave J is offline   Reply With Quote
Old 04-20-2013, 10:41 PM   #18
Electrical Enthusiast
Rewards Points: 504
Bingo. There are lots of set ups that may function, and may even be reasonably safe, that will not meet code for one reason or another.
Kyle_in_rure is offline   Reply With Quote
Old 04-20-2013, 11:12 PM   #19
No, we just bust balls about it, and then there are some on here that take it too far to the extreme, when it comes to ball busting.
If you can use a pencil and paper, draw your land drawing out that way, with distances, which if you can get the info from your county building, they may show the info. Otherwise, get a buddy or kid and have them help you use a hundred foot tape to measure.
After you draw out the land sketch, just scan it into your computer if you have a all-in-printer as a jpg and upload, by clicking the "Manage Attachments", you can then attach the drawing.
Now if you have a iPhone or Android, there is actually some decent apps like the MotionX GPS app, which is a really nice app http://gps.motionx.com/iphone/overview/ to use to mark where the house is, garage, and where the pump will be. At times, technology does come in handy for stuff, other than playing games and listening to music.
Old 04-21-2013, 07:39 AM   #20
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
If that is acceptable, is it also acceptable to simply ground the remote box to earth instead of including a ground wire with the buried wire as long as the source is also grounded to earth? Or is a ground wire always required in any wiring on the load side of the main box?
You MUST run a separate ground wire!
The Following User Says Thank You to stickboy1375 For This Useful Post:
Dave J (04-21-2013)
Old 04-21-2013, 07:15 PM   #21
Rewards Points: 14
Just out of curiosity, if both ends are grounded to earth, why is the ground wire necessary? Aren't they bonded to each other by earth? Is this truly a safety issue, or just a redundancy in the code?
Old 04-21-2013, 07:19 PM   #22
E2 Electrician
Biggest misunderstood item in the Electrical field... the EARTH plays NO role in an electrical system and functionality of the ground fault protection.
Old 04-21-2013, 07:47 PM   #23
You need a Hot, Neutral, and Ground for equipment like pumps to work properly. If you do not have a ground between it and the panel, then you create what is called a "Floating" ground, and that in itself becomes a safety issue. Unless the pump is 120v/240v, it would need all four wires, otherwise, if it is just 240vAC, it is just three wires.
As for a sub-panel, you need two hots, a neutral and a ground between them, otherwise it will not work, and would be a safety issue.
I really hope you do not work on electric or repair anything electrical.
Old 04-21-2013, 08:57 PM   #24
Semi-Pro Electro-Geek
Rewards Points: 2,938
The earth doesn't do any bonding. It's not very conductive. Grounding electrodes serve a few useful purposes, but protection from ground faults is NOT one of them. Grounding electrodes play no role whatsoever in protecting from ground faults. Ground faults are protected against with BONDING, which is a low-resistance metallic path from the equipment back to the utility neutral. The only way a breaker will trip and clear a ground fault is if the equipment is BONDED, not just "grounded". Confusingly, the wire that does the bonding is called the "equipment grounding conductor" or "ground wire". But it's main function has little to do with connection to the actual earth, and everything to do with connection to the utility neutral at the service entrance. That's why you need a separate grounding conductor. Without it, having a grounding rod at the distant equipment is WORSE than nothing, because a ground fault will electrify that rod and cause an even bigger hazard.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
stickboy1375 (04-21-2013)
Well Pump wiring question gfreely232 Electrical 24 04-16-2012 03:13 PM
Power 120V Pump from a 240V circuit RoberTX Electrical 26 07-05-2011 11:43 PM
Swimming Pool Pump & Salt Water Ctlr Wiring brianr Electrical 1 06-27-2011 06:02 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
Wiring 240v pump to generator - URGENT Benchr Electrical 4 12-19-2006 05:50 PM
