Wiring A Display, Help!! - Electrical - DIY Chatroom Home Improvement Forum
Old 06-21-2012, 08:43 AM   #1
Question
Wiring a display, help!!
I am building a display using a Cutler-Hammer panel: BR3030B150V2. It is a 150A 30/30 space/circuit panel. It has a 100A main breaker without any lugs, just the srews on the breaker itself.
I am trying to make this display as accurate as possible. I was wondering what size wire and how to wire the feed to the panel.
Thanks. Any help would be greatly appreciated.
Penguin is offline   Reply With Quote
Old 06-21-2012, 09:17 AM   #2
Licensed electrician
Rewards Points: 1,742
Are you trying to show how a real panel would be wired?
Old 06-21-2012, 09:35 AM   #3
Yes. It will not be energized, I just want to show how it would look if it was hooked up for real. How it is fed and a few branch circuits.
Old 06-21-2012, 10:38 AM   #4
I suspect what you may have is a main lug only panel. This would be typical for a non-service panel. Service panels have a main breaker already mounted and the incoming conductors attach to them.
Old 06-21-2012, 10:42 AM   #5
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
#2 SE AL cable.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 06-21-2012, 11:16 AM   #6
It is not a main lug, it is a main breaker.
Will #2 fit under the screws of the breaker?
Should I use 2/2/2/4/? Two on the breaker, one on the netruel bar and one on the ground bar.
Old 06-21-2012, 11:50 AM   #7
electures's Avatar
If it is a 100a breaker it will.
Old 06-22-2012, 01:51 PM   #8
Wired correctly?
Help with wiring issues on a newly purchased house ThatGuy Electrical 13 01-17-2012 10:51 AM
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
