Wiring Dimmer Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 03-17-2010, 08:31 AM   #1
wiring dimmer switch
I know the black from the power source goes to black screw and black from light goes to silver screw and whites get wire nutted together. What happens with the grounds from the power and the light?
raineydr is offline   Reply With Quote
Old 03-17-2010, 08:36 AM   #2
Master Electrician
Rewards Points: 3,684
They get wire nutted together and connected to the device.
brric is online now   Reply With Quote
Old 03-17-2010, 09:03 AM   #3
thanks for the info
Old 03-17-2010, 12:11 PM   #4
installing ceiling fan/light fixture- to existing pull chain light
do i need to run new wiring or can i use what is there to just keep it a pull fan or pull light setup
Old 03-17-2010, 12:15 PM   #5
changing a regular pull chain to turn on light to a ceiling fan/light fixture
i want to change an existing pull chain to turn on light fixture to a ceiling fan/light set up. do i need to run new wiring or can i use what is there to just keep it a pull fan or pull light setup[/quote]
Old 03-17-2010, 12:17 PM   #6
Master Electrician
Are you referring to a ceiling fan and light combination?
Replacing dimmer switch with regular switch? LOUSY CARPENTER Electrical 2 11-05-2010 08:21 PM
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 08:40 PM
Wiring from light to switch and on poorjohn Electrical 3 03-16-2009 02:23 PM
Replacing a single switch with 3 way switch using old wiring chriscam75 Electrical 3 02-17-2009 09:15 PM
installing a dimmer switch from an old switch wilsonfrench Electrical 7 01-11-2009 02:05 PM
