Wiring Digram Luxaire Furnace - Electrical - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 11:29 AM   #1
wiring digram luxaire furnace
need wiring digram luxaire el. furnace F2R024N06B
B
Y
Waldon Richards is offline   Reply With Quote
Old 11-25-2011, 01:29 PM   #2
Have you tried contacting the manufacturer?
http://www.luxaire.com
Billy_Bob is offline   Reply With Quote
Old 11-26-2011, 09:21 AM   #3
Rewards Points: 460
Often on back of blower compartment panel.
diyorpay is offline   Reply With Quote
Old 11-26-2011, 09:22 AM   #4
I'm Your Huckleberry
Rewards Points: 2,270
B is usually common
Y is usually cooling
Doc Holliday is offline   Reply With Quote
Old 11-26-2011, 05:15 PM   #5
Rewards Points: 460
B- For heat pumps, B used mostly for Rheem or Ruud or any manufacturer that energizes the reversing valve in heating mode for the heat pump. Thermostat wire goes to outside heat pump condenser to run for heat. (Other manufacturers of heat pumps use reversing valve for cooling off the O thermostat terminal.)
Y- Cooling or A/C. Goes to compressor relay from thermostat.
Luxaire Gas furnace bolesrs HVAC 6 12-19-2016 03:11 PM
Luxaire furnace flame out Tuckrb HVAC 14 01-28-2012 11:00 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Need Luxaire Forced Air Furnace Wiring Diagram misticvillage HVAC 7 04-15-2009 05:09 AM
Luxaire Furnace mobear HVAC 1 03-13-2005 12:54 PM
