#1 |
wiring Difference Between Backfeed Breaker And Regular Breaker
I learned from internet that generator can be added to main panel by using a back-feed breaker.
A back-feed breaker looks exactly the same as any regular breaker . but this back-feed breaker received the generator and pass power to all the house loads. So how is the wiring difference between back-feed and regular breakers? ( I am not a technician nor engineer.) |
#2 |
JOATMON
When you back feed a breaker, instead of the wires coming out of the breaker going to your circuits (outlets), the generator wiring is sending power into the breaker.
If you look at the back panel of a load cente (breaker panel) you will see a buss bar (flat bar with spikes sticking up). When you plug in a breaker, it's connected to the buss bar. Flip the breaker on and the voltage from that buss bar is now available on the output of the breaker. If you back feed a breaker, the voltage on the terminals of the breaker is now connected to the buss bar. A breaker does not care which direction current flows. It works the same if your using it normal or back feeding it. Very important point.....your main breaker needs to be off if you are back feeding a panel....otherwise, not so pretty things can happen. If your breaker is sized right, the only 'event' should be the breaker tripping. If not sized right.....well....guess you will be asking more questions here.
Common Sense is like Deodorant. Those that need it the most don't use it. My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
Yes, you need an interlock mechanism so that the back-fed generator breaker cannot be turned on unless the main is off. Or a transfer switch.
I'm aware that some jurisdictions require that a back-fed breaker be bolted down inside the panel, to ensure that it can't pop off of the bus while it is feeding power in. |
| The Following User Says Thank You to fa_f3_20 For This Useful Post: | NJMarine (12-31-2012) |
#4 | |
wiring Difference Between Backfeed Breaker And Regular BreakerQuote:
| Display Modes | |
| GFCI Hot tub breaker | nick26 | Electrical | 16 | 08-10-2012 08:48 AM |
| AFCI breaker pops but regular breaker doesn't | bigmacfann | Electrical | 14 | 08-02-2010 01:22 PM |
| Breaker Tripping | Jeridmar6 | Electrical | 15 | 07-10-2010 09:20 PM |
| 20 amp GFCI breaker pops when pool pump is turned on. | jagrunner | Electrical | 11 | 03-19-2010 05:31 PM |
| Pool Wiring | phinfan1266 | Electrical | 4 | 06-27-2006 03:31 PM |
