Wiring Diagram For Three-way Switches With Pilot Light - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-15-2008, 11:07 PM   #31
Unhappy
I got it wrong
Well, I ran all the wires - took power from the house to the three-way-switch with pilot light, then used 14-3 (two travelers and a neutral) from there to the 3-way switch in the garage. Hooked it all up and the three way switches work - but the pilot does not. The pilot says on all the time, regardless of whether the fixture is on or not!
Turns out that the wiring diagram (attached) from Pass & Seymour Legrand is just simply DEAD WRONG. A wiring diagram that I received by email from Leviton (attached) confirms it.
If the pilot light is in the 3-way switch at the LOAD end, then only 3-wire (two travelers and a neutral) is required between the two switches. BUT - if the pilot light is in the 3-way switch at the LINE end (as it is in my case), then 4-wire (two travelers, a neutral, and an additional wire to connect the pilot light to the load) is needed!
Needless to say I am most disappointed that, despite reading the Pass & LeGrand diagram, and asking for help here, I still didn't get it right. Now I have to pull out a bunch of 14-3 and replace it with 14-4... a real waste of money and time.
Hopefully someone else can learn from my experience!
Wiring diagram for three-way switches with pilot light-pass-seymour-3-way-wiring-diagram.jpg   Wiring diagram for three-way switches with pilot light-leviton-wiring-diagram-3-way-pilot-light.jpg
Last edited by SaxTeacher; 10-15-2008 at 11:09 PM. Reason: fix diagram orientation
SaxTeacher is offline   Reply With Quote
Old 03-18-2009, 01:02 PM   #32
Rewards Points: 14
Current Transformers
Does anyone out there understand all the different spec parameters given by different mfrs of these thing?
My 1st post....I'm a novice!
stmijaar is offline   Reply With Quote
Old 03-18-2009, 06:08 PM   #33
Rewards Points: 506
Send a message via AIM to theatretch85
Wow, you do realize its been 5 months since anything was said in this thread and your topic has NOTHING to do with it! Seriously, start a new thread, also start by reading the
Views: 14,594 Announcement: PLEASE READ: Posting Rules and Disclaimer
Found at the top of the forum listing.
theatretch85 is offline   Reply With Quote
Old 03-18-2009, 07:11 PM   #34
Rewards Points: 14
is that good, bad or indifferent?
Actually I'm experimenting with a 3-way switch with a pilot llight on the line (NOT LOAD) side and current transformers come into play.
NO additional wire runs needed in the house for this!.
The Following User Says Thank You to stmijaar For This Useful Post:
GrayHair (04-12-2015)
Old 09-15-2013, 07:53 AM   #35
Wiring Two 3way Pilot Light Switches - Each with pilot light.
Originally Posted by Stubbie View Post
This is what I understand you have and using your 4 conductor cable
I ordered two 3way switches (Leviton 5246-I - 15A Duplex Style 3-Way Switch w/ Pilot Light), each-one with a pilot light so to know when the oil burner is turned on from two locations. Trying to conserve fuel oil burning a direct hot water heater. After searching the web, seems there is no example out there- i hope i can run 2 pilot lights on the same system... appreciate your time, Thanks, Charles
charlesW is offline   Reply With Quote
50+ year old home-all light switches one-way? mudpaw Electrical 13 06-22-2008 01:57 PM
Is a pilot light supose to stay on? simonb HVAC 2 06-11-2008 05:16 PM
help drawing a wiring diagram kaosama05 Electrical 26 02-23-2008 08:15 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 09:37 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 05:45 PM
