Wiring Diagram Symbols For Timer Switch 120v - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2011, 06:15 PM   #1
Wiring Diagram Symbols for Timer Switch 120v
On a similar thread there is the attached pdf diagram. I need one for a 120v system. Please help...
HandyFireMedic is offline   Reply With Quote
Old 04-10-2011, 06:28 PM   #2
joed's Avatar
Rewards Points: 12,852
Change all the 240 volt numbers to 120 volts and the diagram is the same. L1 and L2 are the black and white wires from your cable.
The Following User Says Thank You to joed For This Useful Post:
HandyFireMedic (04-10-2011)
Old 04-10-2011, 09:40 PM   #3
Didn't realize it was that easy. I should have but I didn't.
Old 04-10-2011, 10:14 PM   #4
joed's Avatar
It should be the same or very similar. However each manufacturer will have some slight differences in their devices. It is possible the only one line could be switched instead of both.
Old 04-10-2011, 10:46 PM   #5
Added a small note to same drawing with a question in it. If it's not clear, what do the rectangles mean at the bottom of the relay? I'm not familiar with them in what I understand to be a typical relay drawing.
Old 04-11-2011, 07:29 AM   #6
Rewards Points: 1,580
I believe those are the terminals in the relay box to which you'd connect your wiring.
bob22 is offline   Reply With Quote
Old 04-11-2011, 07:46 AM   #7
joed's Avatar
Those are the relay connection points. You are not going to be connecting to them they are internal to the timer. They are basically the wire nuts you see in the lower left of the lower image. Your connection points are 1,2,3,4 and GRD.
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Wiring Motion Sensor Electronic Lighting Switch consultant Electrical 2 03-07-2010 07:19 PM
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 07:40 PM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 08:37 PM
Ceiling Fixture / Switch Wiring gregger Electrical 1 10-21-2006 07:47 PM
